Results 1 to 7 of 7
    Apr 2017
    nunya business
    e tech 115 or ocean pro 130
    hi all,
    have a few motors all needing work and having trouble deciding which one will make my 14ft ski boat that i use inshore go the fastest, i have a 2000 model 90 degree johnson ocean pro 130 that is on it at the moment, it does 80km/h at 4900 rpm with a 14.125 x 17 prop and it accelerates fairly well, i plan to cut down diameter of prop to try get revs up to where they should be, a 06-07 60 degree 115 evinrude e tech, an 60 degree optical 90 johnson 99 model, and finally a 90 degree evinrude 89-93ish 225, i have reinforced transom with steel and glass tied to floor stringers, also have just made pods to counter some of the added weight so they should all be able to power the boat without the back sitting too deep, thanks for all responses,
    Central, PA
    I'd suggest finding an interested person and see if they'd trade you all of your motors for 1 merc inline 4.
    Oct 2018
    Tennessee
    The e tech is what I would roll with. Imo
    (Rip. Whiteally02) -dad
    Apr 2017
    nunya business
    yeh, thats the plan for now, am going to rebuild it next and see how it performs before making a final decision, the electronics connecting to the lowrance is definitely a big "plus"...
    Lake Coochiching, Ontario
    We had very good experience with a 115 HO Etec, but sold it when we bought a bigger boat. It might be a bit heavy for a 14' boat. The Etec weighs more than the old carb V4s
    If you get the E-tec make sure the exhaust valve has the latest version with the grease fitting. The only downfall to the v4 is the exhaust valve in salt water. Maintained properly it works great. If it doesn't work you will be looking at $4k bill from the dealer.....
    Quote Originally Posted by Bodhi View Post
    Id suggest a slide intake for your promax...
  7. Thanks thunder77 thanked for this post
    Oct 2018
    Tennessee
    Quote Originally Posted by thunder77 View Post
    Lowrance gen 2 is what I currently run also, .. but garmin's has some pretty nice features as well, for a little less than a gen 3 low.
  1. 225 ocean pro
    By Tripps in forum Outboard Engines
    Last Post: 07-15-2016, 04:48 PM
  2. 2000 150 ocean pro replace 2010 115 e-tech?
    By Steve Miklos in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 09-23-2011, 06:39 AM
  3. marine tech needs some auto tech help
    By fkboatman in forum Technical Discussion
    Last Post: 10-24-2008, 10:02 AM
  4. S.O.B. Ocean Run
    By SUPERBASH in forum General Boating Discussion
    Last Post: 07-04-2006, 07:56 PM
  5. Ocean's STV RR
    By OceanmarineB in forum General Boating Discussion
    Last Post: 06-10-2005, 09:20 AM
