Results 1 to 2 of 2
    Apr 2017
    nunya business
    E tech 115 block Interchangeability with optical 90 johnson
    hi,
    i have a 2006 e tech 115 which has blown a piston, i am planning on rebuilding it and have an "99" optical 90 johnson, although the whole carbs, optical ignition, pistons and heads are different both blocks and ports look very similar, am thinking they are both the 1.8ltr? does anyone know if they are actually the same before i tear down 2 engines to find out?? if no one is sure i will post results after i have them dis assembled, thanks
    Nov 2009
    hardyville va
    Quote Originally Posted by thunder77 View Post
    hi,
    Crank and rods are similar and can be interchanged, nothing else is the same.
  1. 3.0 block interchangeability for 225 efi
    By alinder225 in forum Technical Discussion
    Last Post: 08-09-2015, 10:25 AM
  2. 2002 Johnson 175 Carburated Optical......
    By Trippin in forum Technical Discussion
    Last Post: 05-16-2015, 12:04 PM
  3. Mercury Tech: Merc In-line 6 engine block interchangeability
    By rla in forum Technical Discussion
    Last Post: 08-07-2012, 09:57 AM
  4. 115 johnson optical ignition in slow mode
    By sodibc in forum Technical Discussion
    Last Post: 10-03-2011, 09:03 PM
  5. 2.0 Block interchangeability
    By powrguy in forum Technical Discussion
    Last Post: 12-12-2009, 09:45 PM
