Results 1 to 13 of 13
Thread: Any Mercruiser guys here?
03-12-2019, 09:33 AM #15000 RPM
- Sep 2008
- Delaware River,NJ
- 354
Replacing exhaust manifolds and elbows on my other (wife's) boat. Anyone have any comments on Sierra manifolds over OEM?
03-12-2019, 10:44 AM #2
Are yours cracked? Why are you replacing them? I do not think you will gain anything.
03-12-2019, 11:04 AM #3
I would assume your replacing them cause they are corroded. OEM will last much longer than aftermarket. That has been our experience.
03-12-2019, 12:14 PM #4
Buy the factory Mercury manifolds and risers. Believe the newer Mercury’s have an extra coating on them to help prolong the life. Would not trust Sierra long term.
2006 Spectre 24' SCS
2020 Mercury 300 ProXS
2001 Allison XB2003
2006 Mercury 250XS
1988 22' Velocity (sold)
1995 Allison Grand Sport (sold)
1998 Mercury Stock 2.5-260 SS
1990 Velocity 30' - 502's (sold)
Go Daddy Go! Racing
03-12-2019, 01:26 PM #55000 RPM
- Sep 2008
- Delaware River,NJ
- 354
Original on a 2001 boat. Mostly Delaware river. Starboard side was running 45 degrees hotter. Got them off yesterday, they don't look too bad but I'm not waiting any longer and risk a failure. Thanks everyone.
03-12-2019, 02:53 PM #6
Starboard side is always warmer but yeah after 18 years there is probably some scale in there.
03-12-2019, 04:07 PM #76000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
vnemous liked this post
03-12-2019, 05:10 PM #8
03-12-2019, 07:58 PM #96000 RPM
- Jul 2011
- Gloucester, VA
- 1,311
- 19
- 90
- 180
- 342
03-13-2019, 01:54 AM #105000 RPM
- Sep 2008
- Delaware River,NJ
- 354
I winterize by filling motor and manifolds with a 50/50 regular antifreeze according to the manual directions of removing thermostat housing and filling all hoses and intake manifold every year so that must of helped. I don't run the pink stuff through the muffs. Thanks everyone. Ordered tonight from NuWave Marine in NJ. Good guys there.
03-13-2019, 04:55 AM #11
Mercruiser has a manifold and elbow for that engine that is advertised as “hot dipped and powder painted “ these last a long time. This is probably what you originally had. The other option is listed as fresh water and is E Coated. I hope you got the good ones. As far as aftermarket we won’t touch that junk. Down here in our salty environment we have seen that stuff fail in as little as 3 years
Ziemer liked this post
03-16-2019, 11:28 AM #125000 RPM
- Sep 2008
- Delaware River,NJ
- 354
Mercruiser OEM Non-Dry Joint manifolds and Elbows, no risers.
I'm getting conflicting information from calling Mercury and Mercury literature and Service Bulletins.
Loctite 510 on elbow and dry at manifold to head?
Loctite 510 at Elbow and Perfect Seal at manifold to Head?
Perfect Seal on both?
Dry on both
Does the mating surface on the Head, the manifold and elbow have to be bare metal, the new manifolds and elbow are painted there.
03-16-2019, 12:05 PM #13
I use perfect seal on all the bolts. The mating surfaces between the elbow and manifold should be bare metal. Use a single edge razor or a sharpened wood chisel to remove the paint with no gouging. Don't use a grinder since you chance gouging the surface.
21/22 SOB Guys...what size wind deflectors you guys using if any???
By 1deviant in forum General Boating DiscussionReplies: 5Last Post: 03-19-2014, 07:51 PM -
95 mercruiser 4.3
By bec in forum Technical DiscussionReplies: 2Last Post: 04-28-2009, 07:58 AM -
Mercruiser 496
By redfastcar in forum General Boating DiscussionReplies: 6Last Post: 10-22-2004, 07:15 AM
