Results 1 to 15 of 50
03-05-2019, 08:05 PM #1
How To ?! Splitting a foam-filled or foam core boat?
So I've got this clunker jetboat that's been sitting in the side yard for a couple years. Motor runs fine, but the rail was smashed into a pylon, and a lot of water got in. The boat is extremely waterlogged because it's foam filled with crappy bayliner open-cell foam.
Has anyone ever split the rubrail off and separated upper and lower hull halves from a foam-filled or foam core boat?
I know boston whalers are all foam filled, but I searched a long time and couldn't find any examples of them being split apart.
This 14' bayliner Jazz I have looks like an absolute bear to split to remove the old waterlogged foam.
I know most will say pull out the chainsaw and scrap it haha, but the thing owes me nothing and I'm all out of projects. Time to tinker!
Here's a picture of a newer boston whaler foam-filled that I can use as an example... and a picture of the bayliner Jazz jetboat I've got.
1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
03-07-2019, 04:37 PM #2
Really? Nobody has pulled one apart? Guess I'm going to have to do it myself and document it.
It's either going to turn into a restoration thread of another crappy Bayliner... OR get chopped up via chainsaw to the dump haha.1) 1995 14' Bayliner Restoration <--Click
03-07-2019, 04:42 PM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
?? Piano wire from side to side, pulling back and forth through the foam, bow to stern or reverse , two people. Hope it doesn't get hung up?
Old band saw blade with handles on ends?
Or just cut the floor around the perimeter and peel it like a blue banana?Last edited by FMP; 03-07-2019 at 04:48 PM.
loop liked this post
03-07-2019, 04:55 PM #41) 1995 14' Bayliner Restoration <--Click
03-07-2019, 05:01 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Probably need a long broom handle or like to get behind it and maybe help the direction if possible?
Seems like another labour of love, brothers!Last edited by FMP; 03-07-2019 at 05:03 PM.
03-07-2019, 05:09 PM #61) 1995 14' Bayliner Restoration <--Click
03-07-2019, 05:13 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Not a bad plan , but I'd try the tunnel first
03-07-2019, 05:33 PM #8Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Easier to start from scratch and build one....That foam is tenacious. If it is completely foam filled, you are in for the fight of your life.
FMP liked this post
03-07-2019, 06:17 PM #95000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 336
- 134
- 7 Post(s)
That sucks because most bass boats are built like this and they will end up in our dumps
home made tunnel liked this post
03-07-2019, 06:34 PM #10
Saw Zaw
wide blade air hammer
Foam sucks 25 years ago I bought a Stratos full of water.We have invented the world; WE see
03-07-2019, 06:39 PM #11
03-07-2019, 06:50 PM #12Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That blue and black one comes with a setback in place
03-08-2019, 03:52 AM #13
I'm always for a boat being saved, but I'll have to agree with some of the comments above on it being a real pain the ass nightmare. I pulled a partially foamed core glastron 20 ft floor apart.......literally bit by bit, after an hour of shredding and digging I had a 2'x2' section done. Best of luck to you on this project trail
03-08-2019, 07:24 AM #14
acetone injected into the foam? woudn't that dissolve it enough to release!
03-08-2019, 07:49 AM #155000 RPM
- Oct 2011
- Ontario
- 370
- 32
- 46
- 336
- 134
- 7 Post(s)
Acetone won't touch it once the foam has cured. Maybe you're on to something though.
Wraping hi density foam into tight places without using heat and makingthe foam hard
By tunnels in forum Fiberglass and Composites DiscussionReplies: 11Last Post: 01-22-2017, 05:54 PM -
Divinycell Foam Core?
By tj309 in forum Fiberglass and Composites DiscussionReplies: 30Last Post: 10-03-2013, 04:53 PM -
Building materials/ Foam core/ Fiberglass/ Epoxy
By Mhall222 in forum Parts WantedReplies: 0Last Post: 09-07-2013, 02:49 PM -
Foam sheet or pourable foam?
By bigboy in forum Fiberglass and Composites DiscussionReplies: 2Last Post: 11-03-2010, 02:01 AM
