Results 1 to 10 of 10
    Jan 2019
    Manchester Uk
    Water pressure gauge
    I was hoping someone could point me in the right direction with fitting a water pressure gauge, will the pipe/sender screw into the block using the bolt in this picture?
    Also, I have a two piece exhaust plate (I think) on the port side is an elbow and hose. What should this be connected to?
    Any help much appreciated. Chris
    Sep 2017
    Ashland city tn
    Water pressure will adapt in top block where urs has a plug,
    Got a pic of plate and hose?
    Jan 2019
    Manchester Uk
    You can just see the hose on the left here
    Chris
    Sep 2017
    Ashland city tn
    I believe that hose t into ur tell tale
    Jan 2019
    Manchester Uk
    I was thinking that. Currently doesn't have a tell tale just water discharge from the port thermostat? Should I pipe this to exhaust plate with a tee for tell tale?
    Chris
    Sep 2017
    Ashland city tn
    Yep. From stat to adapter then a t for tale tell
    Jan 2019
    Manchester Uk
    Perfect. Once again help much appreciated! Won't be long until she's on the water
  8. Likes Merc 2.5 liked this post
  9. #8
    Jan 2019
    Manchester Uk
    The gauge arrived with an 1/8th npt male adapter for the block. The bolt that's in looks larger. Does anyone know what thread they are?
    Chris
  10. #9
    Sep 2017
    Ashland city tn
    Not sure of thread but u should b abke to find rite parts to adapt down or find sumthin like thisClick image for larger version.
  11. #10
    Jan 2019
    Manchester Uk
    The cooling system is now plumbed in with all new rubber hoses. I went to remove the thermostats however the bolts feel tight. olne on each side as it happens feels reluctant to undo.
    I didn't try hard, it's a very old engine... don't really want the trouble of extracting snapped bolts etc
    do i run it as is? When started water flows from stats straight away...
    Chris
  1. Replies: 2
    Last Post: 09-04-2014, 05:33 PM
