Results 16 to 30 of 35
    Aug 2018
    Maryland
    Props are ready. Question for you guys, what would the possible downside be to cutting off even more of the tube. My boat hates stern lift. Is there a point where you can take off too Mitch tube?Click image for larger version.
ID:	433527Click image for larger version.
  2. #17
    Sep 2018
    OSYKA, MS
    Go look on Mercury website at the BRAVO OC.
    The prop tube is cut off at the base of the blades.
    I don’t think you could go any shorter than that.
  3. #18
    Aug 2018
    Maryland
    Quote Originally Posted by MDRURY View Post
    But it is there any downside?
  4. #19
    Oct 2009
    Gonzales, La
    I had a bad experience with a 29" Tempest+ one time. It had terrible blow-out and I always attributed it to the short diffuser. Maybe it was the blade shape, I don't know for sure.
  5. Thanks bmedfo1 thanked for this post
  6. #20
    Quote Originally Posted by bmedfo1 View Post
    Call Mercury Racing and ask. Let them know your setup. I would definitely do some homework before cutting the beautiful props
    21 Intimidator 300x Sold
    http://www.youtube.com/watch?v=KBoYUJ58sLE
    1/2 21 Skater 300x Sold
    http://www.youtube.com/watch?v=tKNFL8b6kWo
    30 Activator 850 HP Sold
    https://youtu.be/NZgOTNGKzqg
    30 Concept Twin 300Rs
  7. #21
    Since you are running twins and it hates bow lift have you tried spinning the props in vs out assuming your turning out?
  8. #22
    Feb 2014
    Missouri
    Last I heard the tube didn’t do much to lift stern or bow.
    Rake of the blade does that.
    Have seen it affect slip.
  9. Thanks bmedfo1 thanked for this post
  10. #23
    Aug 2018
    Maryland
    Quote Originally Posted by Trimmed Out15 View Post
    You are correct, I am spinning them out, that is how concept sets them up. turning in should pull the stern down on a v hull so I have been thinking of giving it a try. I asked the manufacturer and asked on a specific Concept page and got lots of feedback from those that have tried saying either no difference or that it made the handling bad at speed and docking. knowing that every set up is different i am still entertaining the idea and appreciate the suggestion. I made the mistake of making more than one change at a time already on this boat so my plan is to run these props and start my own thread with the results.
  11. #24
    Cant wait to see how it works out. Turning it def makes docking harder especially with a stepped bottom. When will you be testing the new props? Did you go down and inch or 2 in pitch going from a 4 blade to a 5?
  12. #25
    Aug 2012
    Tenkiller Lake, OK
    Spinning in pulls the stern down. Spinning out lifts the stern.
    http://www.mercuryracing.com/prop-sc...de-efficiency/
  13. #26
    Good read
  14. #27
    Feb 2012
    Syracuse,NewYork
    Let us know how you make out....
  15. #28
    Oct 2009
    Gonzales, La
    I just bit the bullet and ordered a 28”, 15.25 dia max5 ST.
  16. #29
    Feb 2012
    Syracuse,NewYork
    What boat do you have?
  17. #30
    Oct 2009
    Gonzales, La
    1990 23’ eliminator/400r
  1. 3 Prop comparison with data
    By fishfearme in forum Props, Setup, and Rigging
    Last Post: 08-01-2016, 09:40 PM
  2. Prop comparison
    By tony brimeyer in forum Props, Setup, and Rigging
    Last Post: 10-10-2014, 04:50 PM
  3. ET vs. Drag prop comparison
    By Mr. Demeanor in forum Props, Setup, and Rigging
    Last Post: 04-10-2011, 10:03 PM
  4. prop comparison
    By lild in forum Technical Discussion
    Last Post: 01-18-2009, 07:19 PM
  5. prop comparison?
    By mercrazy in forum Technical Discussion
    Last Post: 11-26-2001, 09:24 PM
