Results 1 to 15 of 35
Thread: 5 blade prop comparison
03-03-2019, 04:40 PM #16000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
The hd sportmaster seems to run best with very high running heights and 5 blade props. My boat with a 400r was fastest with a [borrowed] max5. I also ran a p5x and Maximus but they were both too small pitch and on the limiter. Anyway, I’m ready to buy a prop and noticing there are actually lots of options:
Merc max5
Merc maximus
Hydromotive p5x
bblades 5 speed
Signature SL5
cutting edge series III 5 blade
All the above props are large hub, 15”+, and round ear. The max5 is the most expensive at $2k+. Cutting edge and signature are the cheapest at $650. All the rest are comparable at 12-1600.
Does anyone have experience, opinions, or data comparing these props?
03-03-2019, 05:06 PM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Only 5 I’ve tested was a high 5 and mainly for a whole shot ski boat set up.
I would almost consider regearing earring if you can turn 5 blades on the limiter at 28” or more pitch.'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
03-03-2019, 05:35 PM #36000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Regearing the hd sportmaster isn’t an option.
03-03-2019, 05:40 PM #46000 RPM
- Dec 2002
- Southside, Al.
- 1,243
- 54
- 39
- 81
- 396
You see this thread? Cheaper alternative to the $5000 Mercury CNC propeller
03-03-2019, 06:11 PM #56000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Absolutely. It’s another consideration, just on the upper end of the price scale versus the ones listed above and very different from anything I’ve tried so far. I can’t seem to experiment with one for less than $2150. Also, per the original post, I was trying to compare similar props (large hub, large dia, round ear).
03-04-2019, 01:38 PM #6Junior Member
- Aug 2018
- Maryland
- 16
- 13
I am also in the market for a set of new 5 blades. I have talked to cutting edge and Auggie is working on a set of 5 blades based off the max5 for me right now that are a different casting from the series III. IMO the stock maxumus is just too much material for the 400r but can be labbed and cut down (bblades can even turn it into a max5) I also talked to Brett at bblades and he is working on making a high rake 5 blade like the max5 out of his 5 speed that will be called the R5 but will not be ready until mid summer.
engineermike thanked for this postHydroSkreamin, Toffen liked this post
03-05-2019, 04:21 AM #76000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
No regear, gonna suck for us if we get one at 7500’. Something to look forward to when season starts.
03-05-2019, 07:23 PM #8Member
- Jul 2018
- LOTO
- 41
- 22
- 30
I have a 32p Hill SL5 i run on my 300r Liberator from time to time. I had a max5 that was lost after a shaft failure. Im still screwing with motor height, but Im sure you have seen what Randy was getting out of The 21 Liberator with the Max5. Recently bought a 15.25x34 Merc cnc cleaver and ran 106 @ 6300 with a ton of water pressure. With the engine at the same height the 32p Hill SL5 ran 92 @ 6400. I was on the limiter easily with the SL5. Interestingly, The SL5 ran the exact same speed of 92 with the motor 3/4" lower. At this engine height my 34p Max5 would only do 96@6300.
engineermike, bmedfo1 thanked for this post
03-05-2019, 10:30 PM #96000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Thanks, kingofbeers! To dumb it down for me, can you post the props you tried and what speeds they ran?
03-05-2019, 10:39 PM #10Member
- Jul 2018
- LOTO
- 41
- 22
- 30
34p Max5 with prop C/L +1 5/8"......96@6300
32p SL5 with prop C/L +1 5/8"........92@6400(on limiter)
34p merc cleaver prop C/L +2 1/4"..106@6300
32p SL5 with prop C/L + 2 1/4".........92@6400(on limiter)
I was on the edge of water pressure limits with the SL5 at +2 1/4". Seems the SL5 has much more stern lift than the Max5.
Still had 35+psi with the Merc cleaver at +2 1/4" so motor can come up more with ghe cleaver, but probably not with the SL5.Last edited by KingOfBeers; 03-05-2019 at 11:06 PM.
03-05-2019, 11:52 PM #11
Trimmed Out15, Toffen liked this post
03-06-2019, 12:06 AM #12Member
- Jul 2018
- LOTO
- 41
- 22
- 30
Id bet the numbers would be better for the Max5 if I had the motor higher...but its at the bottom of the Delta. Randy pulled some good numbers with the 33p and 34p Max5. He also ran a smokin 112mph with the 34p merc and Hill cleaver.
Ive only got one run on the Merc cleaver so there is sure some room for improvement. Ive got Auggie at Cutting Edge building me a 15.5x34 cleaver to see how it runs.
HydroSkreamin liked this post
03-06-2019, 01:06 AM #13Member
- Jul 2018
- LOTO
- 41
- 22
- 30
03-07-2019, 04:38 PM #14Junior Member
- Aug 2018
- Maryland
- 16
- 13
03-07-2019, 08:56 PM #15Member
- Jul 2018
- LOTO
- 41
- 22
- 30
3 Prop comparison with data
By fishfearme in forum Props, Setup, and RiggingReplies: 3Last Post: 08-01-2016, 09:40 PM -
Prop comparison
By tony brimeyer in forum Props, Setup, and RiggingReplies: 3Last Post: 10-10-2014, 04:50 PM -
ET vs. Drag prop comparison
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 2Last Post: 04-10-2011, 10:03 PM -
prop comparison
By lild in forum Technical DiscussionReplies: 19Last Post: 01-18-2009, 07:19 PM -
prop comparison?
By mercrazy in forum Technical DiscussionReplies: 1Last Post: 11-26-2001, 09:24 PM
