Results 1 to 11 of 11
03-03-2019, 12:13 PM #15000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
Whats better? 250 EFI mere or 250 opti
Hi guys i just got a boat with a 250 refi merc, im not sure if this is the right place to post it, but im wondering what motor is better opti or efi and what are the differences? Also what would be some general maintenance on this motor? its on a activator.
Thanks
Justin
03-03-2019, 02:21 PM #2
both good motor however the EFI is thirsty and the opti will get almost triple the gas milage. Less stuff to go wrong in the EFI. JMO
03-03-2019, 04:28 PM #35000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
Do they have fuel injectors? the motor has been sitting for 7 years and runs, i will be cleaning the vst but if there are injectors i want to take them out and clean them
Justin
03-03-2019, 05:02 PM #46000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
What are future plans, the opti is an as is engine theirs a few mods, but nothing like the efi mods available.
Opti tend to last (here anyway) longer then the efi. If taken care of
modified efi though are stout.
A properly set up opti has a big bottom end and some people like that over the efi.'06 Tracker All-Fish/Tournament V-18 90 Optimax, 46.8 gps Goal one complete reach 45 mph.
03-03-2019, 05:04 PM #5Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,645
- 606
- 923
- 1699
- 7152
- 3 Post(s)
The 250 efi makes great power and last forever due to the fact that they typically run rich, therefore they stay well lubricated and run cool. Downside is fuel consumption- like vnemous said, but fuel is easier to add to the tank then pistons and air pumps are if an optimax acts up. My recommendation would be to pull the gearcase off (have it pressure checked for leaks, check the gear lash, change the impeller, and change the fluid). Send the injectors off to be cleaned and flowed, flush the VST and replace all of your fuel system filters. Make sure the tank is drained and flush it the best that you can so you don't pollute what you just cleaned.
You also have options to make additional power with your current motor. Todd D. (here on the board) has built some that run very well. I would contact him for the recipe if you are interested in some more squeeze.
Bullet89 liked this post
03-03-2019, 05:07 PM #6
Yes both have fuel injectors, the opti also has air injectors and a fuel rail with diaphragms that sometime need servicing if a run problem. The EFI can last 1000+ hours before rebuild if taken care of. I have 1300 hours on a 250 that still shows cross hatch in the cylinders. The opti had a couple problems with fuel injectors, rails and compressors but were all service bulletins that should have been taken care of. Its something to check.
03-03-2019, 05:10 PM #75000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
are the fuel injectors located in the throttle body? is that a big project to take apart?
Justin
03-03-2019, 09:23 PM #8
Depends what motor you talking about. EFI they are in the plenum. On the Opti they are on the heads of the motor on the fuel rails. Opti's are easier to get to than the EFI but neither is a big job.
03-03-2019, 09:50 PM #95000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
i have an efi, so that would involve taking the throttle body off and the rail sits in there correct?
03-04-2019, 06:32 AM #10
Yes they are.
03-04-2019, 10:53 AM #115000 RPM
- Feb 2019
- Plainview, NY
- 142
- 66
- 11
thank you very much for your help!
The Mere Merc 2.5 Trim Solenoid
By WillySteve in forum General Boating DiscussionReplies: 6Last Post: 02-04-2019, 07:14 PM -
Regular 225 Opti vs 250 Opti XS
By stingray240cs in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 9Last Post: 02-06-2018, 03:28 PM -
Mercury Tech: mere 3.0l fuel curve
By R.grover in forum Technical DiscussionReplies: 0Last Post: 01-06-2011, 06:32 PM -
Dual Repower 225 opti, 225xs or 250xs/opti
By fishnchips in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 10Last Post: 02-18-2008, 08:18 PM -
cool towables??? whats good.. whats not?
By wing nut in forum The Scream And Fly LoungeReplies: 17Last Post: 07-26-2005, 10:59 AM
