Results 1 to 15 of 16
    Feb 2007
    central Kentucky
    20 inch 280 less than 100 hours
    1999 280 20 inch motor less than a 100 hrs ddt shows never turn over 6000 rpm. Comes with trim pump and what you see in pictures.Will sell separated but power head must sell first. Drop on power head $7500 or complete motor $10,750.00 call 270-763-2833Click image for larger version.
ID:	432410Click image for larger version.
ID:	432411Click image for larger version.
ID:	432412Click image for larger version.
ID:	432414Click image for larger version.
  2. Likes upyours, seychellesboy liked this post
    Feb 2007
    central Kentucky
    Btt
    Aug 2009
    mpls,mn
    adds up to 65hrs ?
    Feb 2007
    central Kentucky
ID:	433673I agree 65 is less than a 100 I stated less than a 100 sorry do not understand why software shows 97 but that's what it has.Here is other frame put one on twice on original post
    WI
    I believe one cannot delete the "total hrs" on a 280 ECU but the run time hrs can be reset, which would be done if somebody rebuilt it and wanted to know the total hrs on rebuild. I would assume that would be the reason why these numbers don't add up. If I'm wrong I revert you to my avatar
    I have a boat or two.... that I never get to drive
  7. Likes Michael J Giesler liked this post
    Feb 2007
    lily lake WI
    On some ecu's for some reason rpms between 7000-8000 don't record hours mine 280 showed like no time and i know that's so so wrong lol
    Feb 2007
    central Kentucky
    reduced price
    Jun 2018
    location
    minocqua, wis
    a 280 and never turned over 6000 who believes that? not possible .3000 /3999 shows 24 hr cruising what at 40 mph i get that .but nothing above that ??? what boat was the motor on? think the ddt is a bit kilter
    Delcambre, Louisiana
    I looking to trade my 225 pro max for a 280 Merc offshore race motor for my 225 pro max.
    I also have a Mud Buddy. BOSS DRIVE 58 hp with a spare engine with all Billet internals with just the hours run on the Dyno . Sell are trade
  14. #12
    Feb 2007
    central Kentucky
    Central Kentucky
  15. #13
    Sep 2014
    Still available?
  16. #14
    Jun 2018
    Al
    Gota agree a 280 thats never been turned over 6000 is bunch of �� lol
  17. #15
    Feb 2007
    lily lake WI
    Quote Originally Posted by eli View Post
    They are not always right the ddt and ECU my grandsport has less a hour run time on it over 7000 rpms but yet I've hit the rev limiter over 1500 times lol I did buy a 280 with 115 hours on it it never saw the rev limiter or 7 grand most were idling or under 4000 when the motor was taken apart did a leak down test first all the cylinders were 2% except for one was at 3 still had Factory side pin Pistons the motor looked super clean inside and none of the cylinders had to be straightened still straight the engine builder give it a light hone and put it back together with new top pin Pistons that is a very very rare case but it can happen
  1. 93' 2.5 L 25 inch 305 hours $3495.00
    By JPEROG in forum Outboard Engines
    Last Post: 05-02-2017, 10:00 PM
