Results 1 to 7 of 7
Thread: Tower of Power carb selection
03-01-2019, 02:47 PM #15000 RPM
- Dec 2018
- Maine
- 137
- 22
I am building a early 70s 115 from scratch and wondering if I can use the kd1 carbs from my 1250 and just change jets if needed? If not which model carbs should I use? The 115 used several models over the years but I have no idea what the difference is or if you can't use certain carbs on certain years?
03-02-2019, 10:48 AM #2
Should be no problem, may need to rejet as you said , no drag back feature to worry about .
03-02-2019, 01:13 PM #3Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
How about those tc adapters and use three TCs?
https://www.screamandfly.com/showthr...ters:thumbsup:
You could find 3 mid - late 90s tc carbs from a FORCE. They have idle screws, have low -mid range air jets for better tuning, screw in mains, 42mm venturi, 45mm bores. They use a primer squirter , no choke plates. You'll need to switch the throttle linkage starboard to port on the carbs.Last edited by FMP; 03-02-2019 at 01:39 PM.
03-02-2019, 03:13 PM #4
I think the mounting flang on the TC carbs are horizontal and the flang studs on the inlne manifold are diagonal . THE adapters are $100 plus 3 carbs change the linkage . i don't think you'll gain any performance probably over carbed with the 1250s . The linkage on the inlines runs vertically down through all three carbs VS a horizontal throttle shaft on the TC carbs , You would need to duplicate the linkage thats on a T2 . Only positive is the primer ,witch can be added fairly easy , if you find a set of the drag back carbs you can plum into the venturi fitting for your primer simple and clean .
03-02-2019, 03:15 PM #5Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
That's what the adapters in the above link are for. Plus a little shaping to fit profile.
03-02-2019, 03:43 PM #6Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Heard years ago it worked well, probably still applies today?
03-02-2019, 07:44 PM #7Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Later inline carbs had a leaner mid range with bleeds?
Power Trim Unit for 1978-1979 Mercury Tower of Power
By 1975ss14 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-05-2018, 01:40 PM -
Mercury 115 Tower of Power power trim
By baja030 in forum Outboard EnginesReplies: 14Last Post: 11-11-2017, 11:16 AM -
Carb selection
By cocacola in forum Technical DiscussionReplies: 4Last Post: 11-16-2007, 09:00 AM
