Results 1 to 5 of 5
02-28-2019, 11:51 AM #15000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
1990 Mariner Magnum II and Parts Motor
20" Mid
Does not have the original small diameter lower. Upgraded at some point to the larger one.
This motor spent all its life on freshwater lakes, used in saltwater a few times, there is not any rust anywhere on it.
The motor has a full electrical system off a 1996 Mercury 150 (dual regulator 40 amp system)
Compression is as follows:
1 - 130
2 - 125
3 - 135
4 - 125
5 - 130
6 - 125
Motor starts right up at the turn of the key and sounds really healthy, I can send a video of it running. Only negative is the cowl is cracked right where the front latch goes. Can probably be fixed pretty easily.
Also included is a 1996 Mercury 2.0 150 Fat Block. Motor blew pretty bad. But the rest seems to be in good shape. I purchased it for the electrical system, I was going to rebuild it but plans changed. It is on an older 20" mid and the motor sat and the steering is locked up. But the trim unit works up and down. There are good parts there, trim unit, carbs, intake, etc.
$1800 obo or trade
03-05-2019, 09:17 AM #25000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
New Price of $2000
03-28-2019, 07:46 PM #35000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Bump $1800
04-14-2019, 10:04 PM #4New Member
- Sep 2012
- Argentina
Hi, could you give me a phone number?
Thanks!!
04-15-2019, 08:13 AM #55000 RPM
- Mar 2017
- Miami, FL
- 358
- 10
- 47
Mariner Magnum VS Regular Mariner
By XstreamVking in forum Technical DiscussionReplies: 1Last Post: 09-02-2010, 07:08 PM
