Results 1 to 8 of 8
02-25-2019, 04:14 PM #1
Whats a good two part motor paint?
Guys:
Some of you have been great about giving me advice about repainting my OMC/BRP M1 charcoal gearcase to gloss white so it will match my motor.
I've been thinking about using a 2 part urethane paint, that I could spray on and it would be more durable than the OEM rattle cans.
My idea is to buy a Preval Sprayer and lay this 2 part paint on after priming the gearcase and wet sanding it with 400 grit.
Do you know if there are any paints available out there that I could use? or you have used?
what about automotive finishes? I'm told NAPA will mix it if you give then a paint code, but I don't know if they add the hardener to it or not.
What have you guys painted you motors with? (not the cwol, the leg and gearcase, clamps, etc..)
Thanks!
Boats are like Potato Chips..You can't have Just One1
1974 Hiliner Gypsy 260 Volvo SX
1972 Hiliner Adventurer CC 200 Evinrude OceanPro
1994 Sea Nymph 1462 25 Evinrude
1989 Boston Whaler 13 w/40, then 50 Johnson (sold)
1970 Wellcraft V-20 Steplift, Evinrude 155 Commercial (sold)
02-25-2019, 06:34 PM #2
You likely to get a bunch of different opinions on this, so....
I am a hobbyest painter....I personally like 2 part urethane paint for this, base/clear just because that's what I know how to spray, and will be doing my promax like I have done many 20+years ago...
Nason brand because it has held up for me and is less expensive. Lower units usually get painted a bunch anyway due to a wide array of reasons...
If your familiar with a certain paint and know how to apply it, try that.
Most of the paints you buy are of decent quality, the problems usually are in the prep, conditions when sprayed or the one doing the spraying.
jmoJames H. W2F a V-King... Want 2 Fly a V-King
loop liked this post
04-04-2019, 10:31 AM #3
yes
anything with added hardener in it will be WAY better than anything out of a rattle can. Even the Majic implement paint that tractor supply sells works good with if you buy the hardener to mix with itlimited skills
04-08-2019, 07:42 PM #45000 RPM
- Sep 2011
- Deplorableville
- 740
- 1281
- 76
- 3144
- 1452
I'd second the nason paints.
04-09-2019, 05:46 AM #5
Most auto refinishing suppliers carry a few grades of paint. I like RM ( BASF ) because I have a close supplier and they have Limco 1 fleet white which is single stage urethane and quite low cost and can be tinted. If you take whatever your trying to color match in they should be able to scan it and match it perfectly
04-09-2019, 03:33 PM #6
If you want it to last forever, Imron. Catalyzed car paint will last better than rattle can. All of it depends on prep and primer/sealer quality too. Can't put Imron over rattle can primer and expect it to last.
W2F a V-King liked this post
04-10-2019, 05:40 AM #7James H. W2F a V-King... Want 2 Fly a V-King
Forkin' Crazy liked this post
08-06-2022, 03:16 PM #8
Dupont Imron! Unless you take a flame thrower to it I don't know of a anything that will shine better and hold up better than Imron. I have painted well over a hundred motors black with Imron and the damn stuff just lasts forever, well almost.
Carter Powell
rgsauger liked this post
cool towables??? whats good.. whats not?
By wing nut in forum The Scream And Fly LoungeReplies: 17Last Post: 07-26-2005, 10:59 AM -
Whats a good small business to start up that pays good?
By WATERWINGS in forum The Scream And Fly LoungeReplies: 36Last Post: 11-25-2003, 01:18 PM -
Ever paint your Garage floor?? Looking for a good paint product.
By Daytona19 in forum The Scream And Fly LoungeReplies: 16Last Post: 05-23-2003, 03:29 PM -
Good paint gun choice for paint/clear?...
By C. Phillips in forum Fiberglass and Composites DiscussionReplies: 20Last Post: 02-12-2003, 08:55 AM -
Whats a good paint For a hydrostream 15'?
By sixabove in forum Technical DiscussionReplies: 6Last Post: 12-24-2001, 07:41 AM
