Page 5 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 61 to 75 of 144
  1. #61
    May 2014
    Livingston, Louisiana
    Attachment 435125
    Six petal rubber coated reeds, with some serious restriction on the outer openings from the cage bolt bosses.
    Attachment 435126
    Installed Chris Carson reeds with factory stops. Has lots of room to stuff them down, but not sure how it would work with having to install the intake in a downward motion, if you would run into clearance problems during installation. I may play with this to see if stuffers could be used once I’m done with all the reeds
    Must have been smokin crack when looked at being able to stuff the reed cages down in front, not much room for reed stops and screws to lower cages into front without modifications, must have threw the bare cage in there with no reed stops or screws. If I was to tighten the crankcase on these, looks like doing it in the crankcase with epoxy would be the way to go. Keeping this one mostly stock except for few minor adjustments, so no changes in cc volume on this one.
  2. Likes W2F a V-King liked this post
  3. #62
    May 2014
    Alright, got some time to fool with mota this evening and got to actually mock it up and take some measurements instead of crossed eyeballing crack smoking method. On this particular mota, you actually got 0.125 clearance to stuff the reeds toward the crankcase before running into clearance issues and modifications. This one only got 0.030. Click image for larger version.
ID:	435330Click image for larger version.
    Attached Thumbnails Attached Thumbnails BF00839D-7DE8-4BBE-8C91-BA3E7928CB0F.jpg
  4. Likes Merc 2.5 liked this post
  5. #63
    May 2014
    Got a little more assembled.
ID:	435421Click image for larger version.
ID:	435422Click image for larger version.
  6. Thanks FMP thanked for this post
    Likes FMP liked this post
  7. #64
    DoktorC , any guru wisdom to share with Forbes?
  8. #65
    No O-ring grooves to recut .. these are gonna be easy ..
    Lets see, gonna need a platform ..
    Couple of 3 x 7's
    Straighten em up a little
    Drill some hold down bolt holes
    Countersink em
    Gonna need some pockets for the injector bosses to sit in
    The bad head is welded, I still have to angle drill and tap the platform's . Maybe put a couple 8mm dowel's in to keep the head from walking . Cross that bridge as they say ..
    I originally bought this multi-cutter head to do blocks. Because a single cutter deal had to run so slow to keep it from bouncing across the dissimilar metals which would leave streaks. This thing is so ******* heavy and always has a cutter touching, I use it for heads and blocks now.
    I had to Make up a correct cutter for the Yamaha chamber too, at least we have one now ...
  9. Likes FORBESAUTO, W2F a V-King, powerabout liked this post
  10. #66
    May 2014
    Choot you da man Chaz, dat der thang gonna do well on da ole flat ya
  11. #67
    Forbyston, daybreak now .. go throw the cows over the fence ... some hay . Hungry like alligator !
  12. Likes FORBESAUTO liked this post
  13. #68
    Jul 2004
    Connecticut
    Some of these posts make me miss ol T-Rex
  14. Likes FORBESAUTO liked this post
  15. #69
    It seemed to have an effect on me today as well ..
  16. #70
    May 2014
    Ok, for you HPDI owners, today I replaced the high pressure pump screens. From what I’m seeing, these things cause all kind of problems and get overlooked. Should be a regular maintenance item.
    I removed the top section of the pumps (parts where the lines go into). Used a small screw to screw into screen and get ahold of it, then used a pair of side cutters and rolled the screw upwards using the shape of the cutters against the body. Then used a pin punch with a larger diameter than the screens and gently tapped the new ones into place.
ID:	436111Click image for larger version.
ID:	436112Click image for larger version.
ID:	436113Click image for larger version.
ID:	436114Click image for larger version.
ID:	436115Click image for larger version.
  17. Thanks foodie thanked for this post
  18. #71
    Jul 2004
    Connecticut
    Are these considered the "hidden' screens on the HPDI? I know there are many sets to your point. Amazing the gentle touch required for maintenance.
  19. #72
    May 2014
    That’s them, often referred to as the mystery screens
  20. Thanks Greg G thanked for this post
  21. #73
    May 2014
ID:	436117Click image for larger version.
    Got the high pressure pump mounted, control modules, and vacuum fuel pumps all installed. Gotta go through the vst and replace filters next and replace high pressure filter. I’ll post pic of these also as I go.
  22. #74
    Forby somewhere on the Mrs. table I think there is a set of finished Yamaha heads ready to go.
    I heard her mumblin somethin about second day air .. I don't know .. above my pay grade
  23. #75
    May 2014
    Welp, got a fine lookin set ov heads in today. Gotta get up off my butt and finish her up now. Got crap going ever wicha-way over here. Buildin four Outboard’s, doin custom work on antiques, putting injectors in a dump truck, and got new cars coming out tha ying-yang with a couple slave drivin women cracking that whip and drivin this train. This is the life. And most of all, gotta get some fishin in sometimes
  24. Likes Merc 2.5 liked this post
  1. best place for powerhead rebuild/lower rebuild on Long Island?
    By play2win in forum Technical Discussion
    Last Post: 08-08-2011, 01:49 PM
  2. Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
    By Liberator*21 in forum Technical Discussion
    Last Post: 10-06-2010, 06:39 AM
  3. Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
    By rickyo in forum Technical Discussion
    Last Post: 06-05-2010, 04:08 PM
  4. Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
    By BroCo in forum Technical Discussion
    Last Post: 07-27-2009, 01:53 PM
  5. 3.3 hpdi hop-ups
    By Red in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-30-2005, 04:32 PM
