Page 3 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 31 to 45 of 144
  1. #31
    Feb 2014
    Missouri
    Blueprinting I see. Always worth a few ponys
  2. #32
    Jul 2004
    Connecticut
    Mad skills for sure.
  3. #33
    Oct 2009
    Gonzales, La
    Just keep in mind....as far as I can tell the hpdi motors do not have maf, map, or o2 sensors. That means the only sensor that communicates load to the ecm is the tps. If you modify engine characteristics much, the ecm won’t be able to accurately infer load/air flow and therefore fuel flow may be incorrect.
  4. #34
    May 2014
    Livingston, Louisiana
    Yeah, another reason not getting to crazy with it. Just trying to customize it a little for what he was looking to get out of it, and keep it on a budget. (These things are crazy expensive, no wonder you don’t see much info about them lol) From the little info I have found Hrdro-tec has made some pretty good hp without modifying ecm’s. I went over all this with cust and explained to him we may have to send ecm’s off or get some for 250 or 300. I do the initial idle time for pistons and first runs on the water, so I can get a good look at how it’s doing and to make sure all is good to make it through break in. Thinking about adjusting throttle so it can’t open all the way and let him run it until broken in. Then we go out in it and monitor plugs at different rpms and make sure it’s not leaning out. Then go from there.
  5. Likes Greg G liked this post
  6. #35
    Sep 2017
    Ashland city tn
    That's what I did to mine for break in , I set throttle stop just over half way, and worked great, , great job on this motor forbe ,, didnt no u dol machine work to , good to know!
  7. #36
    May 2014
    Thanks for the compliments. Normally Don Nickels near me does the majority of my machine work, he does top notch work and can go to him personally to go over what and how I want things done on custom things. I do have a boring bore and do small jobs like this myself. Chaz is doing the heads on this one for me, and got a 3.0l next to do with a bad hole. If the head is messed up, they’re going to Chaz also because of them being o-ring heads. I do all my own porting and anything I can do by hand.
  8. Likes Merc 2.5 liked this post
  9. #37
    Well , this is what I found outside my gate ...
    Good thing Forby did the round and round and round and round wrap. Them heads wern't slippin out no little hole like that ...
    Wait, wut's that I see under the light ...
    Better go in for a closer look under the magnifier .. Pppfftt No wunder FuMP said : "Now ya done it " He musta know'd Yamaha cast those heads out of junkyard Cadilac's ehhh ...
    Only had time to pour a chamber to get a baseline .
    Lets call it 79.2 cc
    More importantly @ this point, (besides fixing the damaged hole) is that a 3/4" reach plug leaves 2-3 threads exposed. Bad for power to "hide" the plug. Even worse if (when) they or a fleck of carbon start glowing ..
    Best fix is the flat that the gasket seat's on should be plunge cut until the plug body is flush or protrudes slightly.
    Then re- CC'd
    Then we can fill in the blanks to make a ed-U-ma-cat-ed guess ...
  10. Likes FORBESAUTO liked this post
  11. #38
    Nov 2009
    hardyville va
    I built a 250 HPDI with a 250 EFI operating system. The motor is still running after a thousand or so hard hours. Its a beast. Don't trust the High Probability of Destruction Imminent operating system.
  12. #39
    Oct 2009
    Gonzales, La
    That’s interesting calikid. I know not of the efi fuel system is there, but you had to swap out the throttle body and efcu, add injectors and rail, and plug di injector holes?
  13. #40
    Nov 2009
    hardyville va
    Quote Originally Posted by engineermike View Post
    Built it with all OEM Yamaha stuff. I used everything off a blown up OX 66 250 EFI, '96 to '04 will work. It's pretty much bolt on. The exhaust cover, throttle body, fuel rail, vst, ecm, pulsar coil, and stator, will go right on. The boss for the O2 sensor is there you just have to drill it out. Use the hpdi flywheel, and the stock hpdi reduction gear starter will mate right up. You can use the 6 pedal reeds off the hpdi, they are nicer than the 5 petal used by the efi. Pretty strait forward.
  14. Thanks engineermike thanked for this post
  15. #41
    Nov 2009
    hardyville va
    I bumped an old post at technical discussions with pics of my project
  16. #42
    Here's what the rest of the numbers look like on the chamber ...
    With such a narrow squish band and deep bowl , I thought the bore was going to be bigger than it is .. I recon thats why we measure stuff ...
  17. Likes FORBESAUTO liked this post
  18. #43
    May 2014
    Updated post 29 measurements of 300 sleeve compared to 225 porting
  19. Likes Merc 2.5 liked this post
  20. #44
    May 2014
ID:	433082Raised exhaust port, has a little more chamfer on port than appears, but I do not put a lot on the exhaust port, only enough to protect ring (it’s a direction and amount of flow thing) The large factory chamfer is gone as the actual port is at the hieght of the old chamfer.
ID:	433083Cleaned and prepped boock
ID:	433085Two upper bearings
ID:	433086Two o-rings in lower cover
ID:	433087Anti- rotation pins on both upper bearings sit in pocket in block and locating ring in groove of upper bearing.
ID:	433089Crank set in place. I also added a couple drops of bearing mount between center mains and block to prevent any movement and chatter of bearings.
ID:	433090Click image for larger version.
ID:	433091Bottom guided rod setup
    Attached Thumbnails Attached Thumbnails 9C70DB1F-C448-4726-B2DA-E2CE53C808D0.jpg   20B44B99-596E-4672-AAD4-38756231F191.jpg
  21. Thanks Greg G, foodie thanked for this post
  22. #45
    May 2014
    Piston comes 0.008 out top of deck and has rounded dome of 0.165. Uses a 0.020 thick head gasket paired with deminsions of head Chaz provided.
  1. best place for powerhead rebuild/lower rebuild on Long Island?
    By play2win in forum Technical Discussion
    Last Post: 08-08-2011, 01:49 PM
  2. Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
    By Liberator*21 in forum Technical Discussion
    Last Post: 10-06-2010, 06:39 AM
  3. Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
    By rickyo in forum Technical Discussion
    Last Post: 06-05-2010, 04:08 PM
  4. Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
    By BroCo in forum Technical Discussion
    Last Post: 07-27-2009, 01:53 PM
  5. 3.3 hpdi hop-ups
    By Red in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-30-2005, 04:32 PM
