Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 16 to 30 of 144
    Oct 2009
    Gonzales, La
    Most of the stuff from HT can be replicated by a good machinist. Cut heads, cut tuner, cut reed cages, etc. I found the biggest improvement to be a modified airbox. My old boat picked up about 2 mph by opening up the rear of the airbox. Complete removal was a bad idea though.
  2. Thanks FORBESAUTO thanked for this post
  3. #17
    May 2014
    Livingston, Louisiana
    Yeah, I’m working on him to let us get the heads cut, thinking I do better than the $690 Hrdra tec wants for the heads.
  4. #18
    Any 300 needing work kicking around on the cheap? Build that and swap if it bolts up.
  5. #19
    May 2014
    Something I’m gonna address during build is gonna be fixing the larger crankcase volume on cylinders 3 and 5 from where it’s opened up for the center main bolts. I got a few ideas with epoxy to resolve. I’ll post pics of modifications, when I complete itClick image for larger version.
  6. #20
    May 2014
    Has anodes in block and heads
    Sent heads to Chaz to get peppered head fixed and up compression a little.
  7. #21
    May 2014
    Let the fun begin
  8. #22
    Now you done it
  9. #23
    May 2014
    Yep lol, changed the ex ports up a little. Fixed a bunch of block to sleeve mismatch and inconsistencies from bank to bank. I’ll get some pics up. Got my hands on a new 300 sleeve and my speculation was correct, only difference in porting is on the exhaust port. Transfers identical. Started my fix for front half, if it comes out worth a hoot it’s gonna be cool and ill also post pics
  10. #24
    How heavy a boat
  11. #25
    May 2014
    It’s on a 2004 Triton Tr20X. Around 1725 empty, no fuel
  12. #26
    Transfer area ^ ?
  13. #27
    May 2014
    Unfinished plugs I’m making to fill the center main cavities in cylinders 3 and 5. Wanted to make sure they fit snug and would lock in place before doing the final trimming and smoothing. Thinking about making a spare set to use as patterns and get someone to make some out of Teflon or billet or something.
ID:	432246Click image for larger version.
  14. Likes 225XCL liked this post
  15. #28
    May 2014
    Some shots of a 300 sleeve ports if anyone interested. Ex port 1.860 compared to 2.050 of 225 and pretty flat tapers off approx 0.030 transfer 2.572 same, booster 2.635 compared to 2.660 on 225, booster is wider 1.610 compared to 1.460(short straight across distance. Behind the liner porting would have to be done to take advantage of the wider 300 booster. The transfer lower ports are higher 5.085 to 5.142 -same width. Booster lower port also higher 4.524 to 4.550 also same width. .Click image for larger version.
ID:	432305Click image for larger version.
ID:	432306Click image for larger version.
  16. Thanks hondatech thanked for this post
    Likes FMP, hondatech, 225XCL liked this post
  17. #29
    Sep 2017
    Ashland city tn
    Subscribe, dnt no how I've missed this til now ,
  18. #30
    May 2014
    Got the sleeve swapped out and porting done. On this build I’m not changing transfers, booster, or lower ports, only cleaning up block behind the liner to make smooth transition to ports. I’m raising the exhaust port to yield 24 degrees blowdown, but putting more arch in top of port than the 300 to make more bottom end and mid range to better suit the boat it’s going on. Porting is done except on new sleeve. I’ll post pics of what I’ve done when get back in shop and finish up new sleeve and clean block up.
  19. Likes 225XCL liked this post
  1. best place for powerhead rebuild/lower rebuild on Long Island?
    By play2win in forum Technical Discussion
    Last Post: 08-08-2011, 01:49 PM
  2. Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
    By Liberator*21 in forum Technical Discussion
    Last Post: 10-06-2010, 06:39 AM
  3. Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
    By rickyo in forum Technical Discussion
    Last Post: 06-05-2010, 04:08 PM
  4. Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
    By BroCo in forum Technical Discussion
    Last Post: 07-27-2009, 01:53 PM
  5. 3.3 hpdi hop-ups
    By Red in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 07-30-2005, 04:32 PM
