Results 136 to 144 of 144
Thread: 225 HPDI rebuild
06-11-2022, 08:42 AM #136Screaming And Flying!
- Jul 2004
- Connecticut
- 6,010
- 465
- 168
- 911
- 951
There were 16 bit and 32 bit ECM's on these motors so also be sure to know which you have.
06-11-2022, 11:01 AM #1375000 RPM
- Aug 2008
- Toronto
- 117
06-11-2022, 11:12 AM #1385000 RPM
- Aug 2008
- Toronto
- 117
Forbesauto...you mention HT, just call them...sure as heck they are not the only ones that have the answers.
If this was a merc, we would have a 100 answers!!
06-11-2022, 11:21 AM #1395000 RPM
- Aug 2008
- Toronto
- 117
It would just be nice for someone to comment "this is what you do" because they have the kit, etc...
06-11-2022, 02:22 PM #140Member
- Jun 2014
- Petawawa, ON
- 90
- 29
Hopefully by the end of the summer I can have some answers. Took a while but myself and a friend have figured out all the channels jn the ECU and will be doing some data logging and tuning later this summer. Work has both of us too busy unfortunately.
Also hoping to delete the 4 cylinder idle and the neutral start switch setup. Would be nice to be able to start it in gear when j want to.
There mapping difference between the different ECU's when you compare them. But haven't dove into what the actual differences are yet.
06-14-2022, 02:36 PM #1415000 RPM
- Aug 2010
- Jacksonville, FL
- 144
06-14-2022, 07:32 PM #142
Do you know what the timing specs are now on the 2.6? I haven’t done one yet to know. If the numbers and blowdown are similar it will tell us a lot about the design of the motor and if it will work.I think they are similar, but not 100% sure to say yay or nay. If ya can get the numbers off the 2.6, we can go from there.
06-15-2022, 03:55 PM #1435000 RPM
- Aug 2010
- Jacksonville, FL
- 144
It's still a good running motor, but low on compression across the board, 102 - 110. I'll be tearing it down this winter. Want to get a little more out of it.
1986 Baker 18 Mod VP, Yamaha 175
2001 Crest Pontoon, 150 Opti
1968 Sears 14' aluminum, Merc 110
06-18-2022, 04:31 AM #144Member
- Jun 2014
- Petawawa, ON
- 90
- 29
I'd be interested to see what's going on inside the 2.6 as well re: port layout.
I worked a 85' v4. Very similar exhaust port specs but had more blow down than my 225 HPDI and less transfer area.
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM -
Yamaha Tech: Turn My 175 HPDI into a 200 HPDI
By BroCo in forum Technical DiscussionReplies: 0Last Post: 07-27-2009, 01:53 PM -
3.3 hpdi hop-ups
By Red in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 2Last Post: 07-30-2005, 04:32 PM
