Results 1 to 5 of 5
    May 2016
    Holden Beach NC
    Magnum (M1) Gearcase propshaft seal Question
    Just got a (new to me) 2004 Evinrude Magnum gearcase from Tinbanger1979. Beautiful gearcase too.
    But since I haven't installed yet, (and its going to live on a boatlift,) I thought I'd have the propshaft and top driveshaft seal renewed before installing it on my motor.
    I spoke with a shop tech at my local Evinrude dealer, and he said he may have to pull the bearing carrier out, to change the propshaft seal.
    I have never heard of this before, why would he have to take out the bearing carrier to change the seal?
    Would this be necessary to change the top (driveshaft) seal?
    I just want to button up this gearcase with fresh seals so I don'y have to worry about it water intrusion
    You thoughts, anyone?
    Boats are like Potato Chips..You can't have Just One1
    1974 Hiliner Gypsy 260 Volvo SX
    1972 Hiliner Adventurer CC 200 Evinrude OceanPro
    1994 Sea Nymph 1462 25 Evinrude
    1989 Boston Whaler 13 w/40, then 50 Johnson (sold)
    1970 Wellcraft V-20 Steplift, Evinrude 155 Commercial (sold)
    Jun 2002
    Winter Haven Fl.
    The seal can be removed with propshaft still in place but not the best way to do it, if you want it resealed have him pull the bearing carrier which isn’t a big deal put a new seal and a new big o-ring on the carrier and replace the driveshaft seal then you know you are good to go after a pressure test. Just my 2 cents.
    May 2016
    Holden Beach NC
    Thanks Oldschool, Thats what I'll have him do.
    Jun 2002
    Winter Haven Fl.
    Sep 2014
    chicago,il
    agreed.there only 3 real seals.upper,lower and the o-ring. pull it out.swap em all out.. you could do the 2 and find out your o-ring is bad..
  1. Mercury Tech: Propshaft seal #s needed
    By Damyankee in forum Technical Discussion
    Last Post: 09-14-2010, 03:08 PM
  2. Mercury Tech: Propshaft seal
    By rdkvector in forum Technical Discussion
    Last Post: 08-18-2009, 02:26 PM
  3. propshaft seal question for Evinrude/Johnson techs
    By fabricator in forum Technical Discussion
    Last Post: 03-03-2008, 08:46 PM
  4. Propshaft Seal
    By njthumper in forum Technical Discussion
    Last Post: 10-19-2006, 09:18 PM
  5. Need propshaft seal part #'s for CLE.
    By LaserModVee in forum Technical Discussion
    Last Post: 08-18-2003, 12:55 PM
