Results 1 to 10 of 10
    Mar 2009
    Port Saint Lucie
    Fuel pump pressure
    Looking at 2 holly fuel pumps. One is 1.5 - 4 psi and the other is 3 - 7 psi, I think. Carburated 3.0 looper. Which would be best? Both self regulating, up to 300 hp motors. Would the 1.5 - 4 psi be enough without a regulator? Would the 7 psi need to be regulated? The 7 psi one flows a little more per hour.
    Aug 2015
    NE Tennessee
    Not an OMC guy, but compare flow rates at the same pressure, and voltage.
    The 3-7 psi may flow the same amount @ the same pressure as the 1.5 to 4 psi pump. Unless they are rated at top psi pressure.
    All this should be in the specifications.
    I like the 3-7 pump. Then regulate it if you have to. jmo
    Jan 2015
    In the factory manual they call for not less than 3psi @ 800 rpm in gear.
    And like W2F above mentioned, you want to check flow rate of pump, Gallons Per Hour.
    I use the Holley red pump with Holley blue pump regulator set at 3-4 lbs on carbs, works for me ...
    Jay
    Jay @ JSRE
    Mar 2009
    Port Saint Lucie
    Ok. I guess the question should be, will the 1.5 - 4 psi one work without a regulator? I know 7 psi is pushing it without regulating.
    Mar 2009
    Port Saint Lucie
    One was 25 gph other was 35 gph if that helps.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by Gorilla0178 View Post
    1.5-4lbs shouldn't need regulated, then again merc says 5lbs pressure , on other hand omc uses quite bit more gas than merc also , in my experiences.
    Bristol, WI
    I would absolutely use a regulator. Will be a far more consistent pressure at the injectors or carbs. My 2 cents.
    Larry Gempp Jr.
    2017 RXP-X 300
    2016 Quartershot T3R
    28 Skater
    2004 HydroStream Venom - 3.4 Etec - August, 2011 S&F Boat of the Month
    Mar 2009
    Port Saint Lucie
    Im gonna, I have a regulator already...
  10. Likes Speed Jr. liked this post
  11. #10
    Aug 2015
    NE Tennessee
    Larger of the two listed pumps with a regulator set to specification... Done
  1. Do I need to run a fuel pressure regulator with a Holley Red fuel pump?
    By Steve2ManyBoats in forum Technical Discussion
    Last Post: 03-31-2011, 08:09 AM
  2. Replies: 5
    Last Post: 06-01-2010, 06:48 PM
  3. fuel pressure stock pump VS elec. pump
    By fastskeeter in forum Technical Discussion
    Last Post: 08-14-2005, 09:03 PM
  4. Fuel pump pressure
    By Darton in forum Technical Discussion
    Last Post: 08-01-2003, 01:30 PM
Talon Powerboats
