Results 1 to 10 of 10
    May 2017
    US / NC
    Mercury 2004 225 EFI
    What is a cheaper alternative for the Starboard and Port bleed tubing . Mercury is kind of steep for 39 inches of tubing ?
    Where kind you get some tubing from .
    Thx
    May 2017
    US / NC
    No one used any other type tubing on there motor.
    Dec 2006
    Central Wisconsin
    I've seen ppl use Tygon tubing available at most small engine repair shops. Different colors available and it looks pretty cool.
    May 2014
    Livingston, Louisiana
    http://parts.promarineusa.com/produc.../30/250/1245/1
    Pro marine has the regular bleed line and Tygon. If ya use the tygon, install small zip ties to the ends, or it can possibly blow off. The tygon is much softer than the factory bleed hose. It looks good though and can see what’s going on, and you can get more trick with the different color ties.
    May 2017
    US / NC
    Thx to every one . That a big help .
    Napa h-174
    May 2017
    US / NC
    Thanks Chaz ....looked on ProMarine ...and there site ,does has any .
    Thx Richard
    Mar 2015
    Oregon
    home depot here sells a orange micro fuel line , 10 foot roll about 5 bucks
    hardware stores usually have tygon fuel line
    both ethanol resistant
    Quote Originally Posted by RiChavis View Post
    Thx Richard
    Napa is NOT the part number at Pro Marine ... Drive down the street anytown USA till you find one of these .. go inside ask for H-174
    Chaz= thinking 1/8" I.D. double wall fiber reinforced EFI / oil , heat / pressure compatible hose makes tygon look like it belongs back in the goldfish aquarium.
  10. Likes RSWORDS liked this post
  11. #10
    May 2017
    US / NC
    Got it Chaz Looks to be the same as Mercury hose . H-174
    Thx Richard
  1. Mercury 2004 EFI 225
    By RiChavis in forum Technical Discussion
    Last Post: 09-28-2018, 09:44 PM
  2. Mercury 2004 EFI 225
    Last Post: 09-14-2018, 01:13 PM
  3. 2004 mercury 250 EFI
    By jfm in forum Props, Setup, and Rigging
    Last Post: 09-25-2010, 03:01 PM
  4. 200 Mercury XS - 2004
    By Wood Tick in forum Four Stroke and Direct Injected Two Stroke Engines
    Last Post: 02-07-2010, 12:59 AM
