Results 1 to 10 of 10
Thread: Mercury 2004 225 EFI
02-21-2019, 09:40 PM #15000 RPM
- May 2017
- US / NC
- 131
What is a cheaper alternative for the Starboard and Port bleed tubing . Mercury is kind of steep for 39 inches of tubing ?
Where kind you get some tubing from .
Thx
02-21-2019, 10:54 PM #25000 RPM
- May 2017
- US / NC
- 131
No one used any other type tubing on there motor.
02-21-2019, 11:04 PM #3Member
- Dec 2006
- Central Wisconsin
- 81
- 7
I've seen ppl use Tygon tubing available at most small engine repair shops. Different colors available and it looks pretty cool.
02-21-2019, 11:26 PM #4
http://parts.promarineusa.com/produc.../30/250/1245/1
Pro marine has the regular bleed line and Tygon. If ya use the tygon, install small zip ties to the ends, or it can possibly blow off. The tygon is much softer than the factory bleed hose. It looks good though and can see what’s going on, and you can get more trick with the different color ties.
02-22-2019, 05:11 PM #55000 RPM
- May 2017
- US / NC
- 131
Thx to every one . That a big help .
02-22-2019, 06:11 PM #6
Napa h-174
02-25-2019, 11:03 PM #75000 RPM
- May 2017
- US / NC
- 131
Thanks Chaz ....looked on ProMarine ...and there site ,does has any .
Thx Richard
02-26-2019, 12:40 AM #85000 RPM
- Mar 2015
- Oregon
- 145
- 7
home depot here sells a orange micro fuel line , 10 foot roll about 5 bucks
hardware stores usually have tygon fuel line
both ethanol resistant
02-26-2019, 09:45 AM #9
Napa is NOT the part number at Pro Marine ... Drive down the street anytown USA till you find one of these .. go inside ask for H-174
Chaz= thinking 1/8" I.D. double wall fiber reinforced EFI / oil , heat / pressure compatible hose makes tygon look like it belongs back in the goldfish aquarium.
RSWORDS liked this post
02-26-2019, 11:10 PM #105000 RPM
- May 2017
- US / NC
- 131
Got it Chaz Looks to be the same as Mercury hose . H-174
Thx Richard
Mercury 2004 EFI 225
By RiChavis in forum Technical DiscussionReplies: 3Last Post: 09-28-2018, 09:44 PM -
By RiChavis in forum Technical DiscussionReplies: 0Last Post: 09-14-2018, 01:13 PM -
2004 mercury 250 EFI
By jfm in forum Props, Setup, and RiggingReplies: 7Last Post: 09-25-2010, 03:01 PM -
200 Mercury XS - 2004
By Wood Tick in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 4Last Post: 02-07-2010, 12:59 AM
