Page 6 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 76 to 90 of 106
  1. #76
    Jun 2009
    Bristol, Connecticut
    And check out my new lower unit I refurbished n coned over the winter and just put on the engine
  2. Likes David liked this post
  3. #77
    Jun 2018
    Floating around
    Wow its really shaping up nice! Looks great man
  4. Likes turboeddie liked this post
  5. #78
    Jun 2009
    Finally got all the gelcoat put on except for the transition on the splashwell
    The red gelcoat I sprayed on the transom last year was a different color than what the supplier had this year, it's actually a brighter red gelcoat now, I like it better than the old red version the supplier had, the dump gun I bought makes spraying so easy and less messy using the quart paper cups
    I resprayed the top and sides red again because the first coat i sprayed a couple months ago was more of a primer coat (and to learn)
    So I rigged up two air hoses using a Y-fitting off the compressor, hung one from the tent and the other kept outside the boat...it was pretty easy to spray the inside and outside at the same time, just used a ladder to hop over the transom to get in an out to refill the dump gun
    ok so i am sick of sanding, I started to wet sand parts of the red and it will be a chore, Hopefully I can sand and polish a few areas before winter including the rub rail and dashboard area... so I can put the rub rail on and mount the steering/controls... so atleast I can get on the water and worry about wet sanding/polishing the rest later
    Because of the difference in red color I may fade in some black gelcoat (with red metal flake) over the two colors as they meet on the splashwell and transom, I'll be doing that within the next few weeks before the weather gets too cold
    let me know what you think
  6. Likes LakeFever, VkingMike, Hippie459MN, tnelsmn liked this post
  7. #79
    Jun 2018
    Floating around
    Lookin great! I too prefer the brighter red it really pops
  8. #80
    Jun 2009
    Best I could do to match the previous gelcoat on the transom to the newer, high quality red...was trying to add metal flake and or some black gradient, went with something more simple.....the two reds kinda have a nice effect and "bloodspatter" looks better than I thought it would,,,next boat will be sprayed as a bare hull haha
  9. Likes tnelsmn liked this post
  10. #81
    Jun 2009
    Anyone want to help me wet sand
  11. #82
    The great corn desert of Iowa
    Don’t know how much you want to spend but that deleted splash well area looks like a good candidate for some SeaDek. Maybe a custom “Hydrostream” or “Virage” logo.
    1971 Sidewinder 14 SS w Johnson 90 v-4
    1959 Texas Maid Falcon w Mercury Mark 35A
    1981 Sylvan Sportster w Johnson 85 v-4
    2006 Harris pontoon with a Yamaha 90
    1969 Sunfish sailboat
  12. Thanks Aaronhl thanked for this post
    Likes Aaronhl liked this post
  13. #83
    Oct 2007
    stuart fl
ID:	510039From one Hydrastream owner to another, message me here on the site with a phone# and I will help out for a day sanding. I’m here in CT for 2 more weeks before heading home to FL. One of the best thread I have seen ever! Bravo!
  14. Likes LakeFever liked this post
  15. #84
    Oct 2007
    stuart fl
  16. #85
    Oct 2007
    stuart fl
ID:	510041 New dream boat
  17. #86
    Minneapolis MN
    Looks great man! I found I was able to get away with dry sanding the gel for the first few steps, and with a much more aggressive paper than I thought I could. I started at 220 dry then 400 dry and switched to wet at 600. It's all in what the paper can handle. I feel like the colored gel I sprayed sanded much easier vs the clear gel. Maybe try a small area first with some 400 and go from there.
  18. #87
    Jun 2009
    Quote Originally Posted by turboeddie View Post
    Really appreciate the feedback and offer to help. With the limited sun after work it will be hard to set a time to sand
  19. #88
    Jun 2009
    Quote Originally Posted by tnelsmn View Post
    Good info maybe I will try a spot at 220 dry to see how it goes, I have the 3M paper I got from the auto supply for my 6" air palm sander, I get what you are saying about quality fo the paper because the 3M paper can flex, Ive got some ebay paper that cracks when you bend it, and if the edges wear/tear on any paper that can lead to scratches, the 3M holds up better on the edges
  20. #89
    Oct 2007
    stuart fl
    OK, good luck with the project. ill be back in CT next summer if you need some help. my boat was a Vegas xt skier. loved that boat.Click image for larger version.
  21. #90
    Minneapolis MN
    Quote Originally Posted by Aaronhl View Post
    I should add that you don't want to take all of the orange peel out with the 220 if you go that route. I removed probably 80-90% with 220, that way I was able to get the 220 scratches out with the 400 etc. without removing excess gel.
    3M makes some awesome paper, thats what I used with all my finishing.
  1. virage restoration
    By aquahaulinass in forum Fiberglass and Composites Discussion
    Last Post: 03-02-2017, 03:19 PM
  2. The last Hydrostream Virage
    By phil blomquist in forum General Boating Discussion
    Last Post: 11-03-2015, 11:09 PM
  3. Hydrostream Virage
    By jjmalkow in forum Ebay Listings and Other Internet Listings
    Last Post: 11-27-2014, 11:26 AM
  4. Hydrostream Virage
    By stvhelm in forum General Boating Discussion
    Last Post: 06-03-2010, 10:16 PM
