Page 2 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 16 to 30 of 106
    Jun 2009
    Bristol, Connecticut
    Quote Originally Posted by Aaronhl View Post
    OK First question for you guys-
    Where do I put flotation?
    The sponsons will be partially open (the nose will be open about a foot like you can see the center floor is and there will be a transom plug too in each sponson).
    The gas tank and battery will take up pretty much all the room in front of the transom.
    So I guess previous posts were accidentally deleted, someone posted a picture and description of the flotation foam in their VKing. On each side of the boat there were long pieces of foam from basically the transom to up past the front seats. That is a good idea I will probably go with when I am ready to put my flotation in. Maybe 1ft x 1ft x 8ft foam boxes I can make myself with two part expanding foam or even sheet foam. I didn't want to put it under the floor again.
  2. #17
    Jun 2009
    When the boat was sitting in the yard before I could put it in the garage, snow caused some damage to the top deck. You can see in some of the first pictures there are cracks right in front of the driver and passenger seat areas. I have since pulled and pried the fiberglass back into place and then fiberglassed the back holding it together. You can still see where the crack formed because I haven't filled and faired it. I really don't want to re-paint the top deck but with all the cracks, oxidation, and splashwell replacement I think I might have no other choice??
  3. #18
    The boxes on my King stayed dry for 30+yrs. I removed the posts to keep your build thread less cluttered. I figured you had seen them.
    Jun 2009
    I don't mind the clutter, it might help the next guy doin this
    Thanks for your ideas about the flotation!!
  5. #20
    longisland
    Looking good!!
  6. #21
    Jun 2009
    Hi guys more pictures coming soon !!
  7. Likes tnelsmn, Laseraddict liked this post
  8. #22
    Jun 2009
    Here is a pre winter update, looking back at the pictures I barely remember doing what I did for parts of the restoration...I've been working on it in the garage for so long now. Well I finally put it back on the trailer and took it out of the garage today. Here is the latest work from spring and summer of 2019. Sorry some of the pictures are upsidedown
  9. Likes tnelsmn, rgsauger, Laseraddict liked this post
  10. #23
    Jun 2009
  11. Likes tnelsmn, rgsauger, Laseraddict liked this post
  12. #24
    Jun 2009
  13. Likes tnelsmn, HydroSkreamin, Laseraddict liked this post
  14. #25
    Jun 2009
    I haven been running my beat up Valero in the mean time so at least I can have some fun on the water before I finish the Virage
  15. Likes Laseraddict liked this post
  16. #26
    Jun 2009
    I bought the Virage used and beat up so it didn't have Hydrostream seats in it. Good thing my Valero has original Hydrostream seats in it because I want to copy them best as I can to use a set in my Virage. So winter project is to make some seat shells and get the reupholstered. Will put a set in the Virage and the Valero
  17. Likes tnelsmn, Laseraddict liked this post
  18. #27
    Jun 2009
    Hope you guys are enjoying the progress. Now that the boat is out of the garage I am going to put the top back on it for the winter with a cover. I had to make some repairs to the top, not all are finished. Getting it ready to install the flat splash-well and top knees in the spring. I will also need to see how well the top fits on the bottom before I take it back off to install the floor mounting strips and wood trim around the top of the bottom of the hull. So I do have a plan and most will be on hold until spring. For now I am going to adjust the trailer.
    Also thinking about painting the boat because the gel is really faded. I want to keep the red and black, hopefully I can bring it to a shop that can make it look good. But not sure if I want to get it painted before I rig it up and test drive it a year or so in case more repairs re needed. Easier to prep for paint without everything bolted up...sorry just thinking outloud, hope you guys are enjoying the story
  19. Likes tnelsmn, starviper10 liked this post
  20. #28
    Minneapolis MN
    Looking great! I dig how epoxy lays down/cures clear. Looks cool.
  21. #29
    Jun 2002
    Winter Haven Fl.
    Keep it up, looks great.
  22. #30
    Plainville, CT
    Like your story. Have a picture of the motor you're going to use?
  1. virage restoration
    By aquahaulinass in forum Fiberglass and Composites Discussion
    Last Post: 03-02-2017, 03:19 PM
  2. The last Hydrostream Virage
    By phil blomquist in forum General Boating Discussion
    Last Post: 11-03-2015, 11:09 PM
  3. Hydrostream Virage
    By jjmalkow in forum Ebay Listings and Other Internet Listings
    Last Post: 11-27-2014, 11:26 AM
  4. Hydrostream Virage
    By stvhelm in forum General Boating Discussion
    Last Post: 06-03-2010, 10:16 PM
