Results 1 to 15 of 21
Thread: Gear ratio
02-14-2019, 10:02 PM #15000 RPM
- Jul 2016
- columbia sc
- 190
Gear ratio
What would he have a better hole shot 1.62 Or 1.75? Thanks
02-14-2019, 10:20 PM #2Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
All else being the same, the 1.75
02-14-2019, 10:46 PM #35000 RPM
- Jul 2016
- columbia sc
- 190
I'm guessing the 1.62 is faster on the big end??
02-14-2019, 10:47 PM #4
02-14-2019, 10:51 PM #5
02-14-2019, 11:00 PM #65000 RPM
- Jul 2016
- columbia sc
- 190
300 pm 20' bullet 30 pitch pro et. Light fly. Svs. Mad efi tuner
02-14-2019, 11:05 PM #75000 RPM
- Jul 2016
- columbia sc
- 190
I have 2 gearcase. 1.75 I know for sure and the hole shot is great.. bought a back up case and the hole shot is allot worse. Just not sure what gear it is
02-14-2019, 11:16 PM #8
mark the drive shaft in relation to a mark on the water pump ot gearcase, put it in gear, roll the driveshaft around until the propshaft makes a full rotation and estimate the percentage it stopped..... you can use a degree wheel for accuracy. The difference between 1.75 and 1.62 is noticeable tho.
02-14-2019, 11:27 PM #95000 RPM
- Jul 2016
- columbia sc
- 190
It's currently on my boat next time I pull the case ill check thanks
02-14-2019, 11:28 PM #105000 RPM
- Jul 2016
- columbia sc
- 190
This case is off a 2001 Merc 225. I sent it to Bob's and then installed it.
02-14-2019, 11:31 PM #11Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
If the lower is bolted to the mid, mark the prop to the case with a marker , mark and turn the flywheel until the prop mark does a complete rotation and lines up. Notice the flywheel rotation : 1 prop rotation.
02-14-2019, 11:36 PM #12
02-14-2019, 11:59 PM #135000 RPM
- Jul 2016
- columbia sc
- 190
Ok good deal thanks for the help guys!!
02-15-2019, 03:10 AM #14Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
02-15-2019, 03:12 AM #155000 RPM
- Jul 2016
- columbia sc
- 190
Great point lol
gear ratio (pro max 300) need help
By dlb in forum Technical DiscussionReplies: 6Last Post: 06-07-2009, 11:10 PM -
1.87 to 1.75 gear ratio ?
By YELLOWSS in forum Technical DiscussionReplies: 3Last Post: 05-15-2009, 02:39 PM -
Gear Ratio ???
By GatorBaiter in forum Technical DiscussionReplies: 3Last Post: 08-17-2005, 08:06 AM -
Gear Ratio?
By wideopen23 in forum Technical DiscussionReplies: 9Last Post: 08-03-2005, 04:13 PM -
Gear Ratio's
By joegucci1 in forum General Boating DiscussionReplies: 2Last Post: 08-13-2002, 10:35 AM
