Results 1 to 11 of 11
    Feb 2019
    Australia
    Optimax 3.0 sportjet
    Hi guys
    I have a sugar sand mirage with a optimax 250hp sportjet in it
    Bought the boat with a seized engine as owner submarined it and pulled water into engine.
    Here in oz trying to find a 250hp power head is near impossible.
    My question is would a 225 opti 3.0 outboard be the same block bolt pattern to bolt in as I can buy complete 3.0 225s way cheaper and easier than finding a 250 power head.
    I am sure the block is interchangeable just trying to confirm.
    Thanks for any advice.
    Ft. Lauderdale, Fl
    Crankshaft splines will be different... you will need a sportjet powerhead or a sportjet crank to put into an outboard powerhead and what ever plumbing is different..............
    Feb 2019
    Australia
    Cheers mate.
    I have done a quick search and I can see both have same crank part number 9784a11
    I know the smaller motors have different crank (13 spline) for sportjet but just hoping block are identical bolt pattern which I'm 99% sure they are.
    Just trying to confirm be for I buy.
    Ft. Lauderdale, Fl
    Quote Originally Posted by Beaver77 View Post
    Cheers mate.
    I looked up too... the early 250DFI outbaords use 9784A14, later they used 842733A02
    Sportjets and Sportjet M2's used 978A11......
    https://public-mercurymarine.sysonli...=englangDB=eng
    Ft. Lauderdale, Fl
    Interestingly tho, the DSI (diesel spark ignition) uses the sportjet crank...............
    Feb 2019
    Australia
    I just check again on Crowley website and the 225 I'm looking at has serial 0g839573 with crank part 9874a11
    My engine is serial 0e433336 with same part number on crank 9874a11
    Is there another site I should be checking part numbers
    Thanks for you help just would not want to buy if it is not suited to my jet pump
    Ft. Lauderdale, Fl
    Mercury site has that 225 crank as 9784T8:
    Ft. Lauderdale, Fl
    Get with Jay Smith here (JSRE), he should be able to give you some insight or even build/rebuild what you need.
    Ft. Lauderdale, Fl
    Feb 2019
    Australia
    Thanks for quick replies just noticed this in part number for the 225
    Maybe superseded
    https://www.crowleymarine.com/mercur...cfm?mdl=X5YGZN
    I'm pretty sure were talking about 3.0L's in the land of Oz ...
    Big place, but the guy to talk to in western Perth is Leon D. Great guy, 3 - 3.0L's on a 22' cat .. so ya know he gotz spares ...
    Beav, if you like I'll PM you his E-mail addy, then you can ask him for his phone number yourself ..
    You young guys are full of energy and must have a lot of money .. Powerheads and crankshafts and what year has what spline and all that ..Your giving me a headache
    Chaz = thinking this here stock driveshaft fits these here coarse spline fruitcake cranks.
    And this here hardened stub I cut off of that driveshaft I shortened for a fella the other day , will weld on to the bottom half of a pump type driveshaft ... and now
    It dont *&%&^*(&%*& matter what crank the motor has, heck be a sport, Don't even look, just stick eeny-meeny-miiny-mo-> up in the seal plate and give it a wiggle and see if it goes clunk
  1. Mercury Tech: 250hp Optimax Sportjet horn /alarm sounds constantly
    By checkmate45 in forum Technical Discussion
    Last Post: 08-12-2018, 12:40 PM
  2. Mercury Tech: 120 sportjet
    By rock in forum Technical Discussion
    Last Post: 06-24-2013, 11:00 AM
  3. Mercury Optimax 250 Sportjet
    By fountain 47 in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 06-17-2013, 04:09 PM
  4. Mercury Tech: 2008 200 optimax sportjet dfi
    By wottz in forum Technical Discussion
    Last Post: 05-21-2013, 01:16 PM
  5. SportJet Optimax Crankshaft Straightening? Is it possible?
    By REPO1 in forum Technical Discussion
    Last Post: 03-22-2013, 05:24 PM
