Results 1 to 15 of 15
    Dec 2011
    Ludington michigan,on the shore
    How do you make a splatter design using gell coat
    How would one go about making a splatter design? Say you had a base color then wanted to splatter some fairly large 1/2" opposing color,how would you do it?
    You have any spray equipment with a large tip? I have a mix that works well for a gun. Without a gun, just use a 4'' paint brush and stay back from the surface, wet and sling the brush. Just do a little at a time till it's what you want. You need some wax additive for either way of doing it. You might want to practice a little before throwing it on the middle of the floor. Like, start under the bow or the rear deck.
    Feb 2010
    massachusetts
    I saw a few people on you tube use a fork dipped in and flicked not sure if it would be good for a large area though .
    Dec 2011
    Thanks for the ideas. The largest tip I have is 2.8MM that sprays gel well. I'll be using Duratec so shouldn't need wax.Im wondering if one of those suction air guns for spraying mineral spirits would work with air turned down.
    Sep 2010
    nj
    Splatter design..nice! And here I am just wanted to repaint the lower units so they look nice and finding out it’s a pain in the a$$
    You can make a web/spatter pattern with that gun using a webbing solution and the duratec. A cup gun works well too. !/2'' drops are hard to do. You will need something that shoots upward and then the drops fall on the surface. A wallpaper brush may work well too.
  7. Thanks outasite thanked for this post
    Dec 2011
    The webbing solution that you speak of,is that gel and Duratec 50/50 shot from the 2.8 tip with the air turned way down,and fluid valve wide open?
  9. #8
    Webbing solution is a separate product. Makes the long strings and can help make globs and spatter. Depends on the application equipment. You will have to experiment with stuff. An old sandblast gun can be used for large spatter. The kind with the hose that goes in the media. Very large orifice. Turn it upside down and make it a gravity feed and it will shoot out some material. Just be ready to keep it moving.
  10. Thanks outasite thanked for this post
    Likes outasite liked this post
    Mar 2009
    Port Saint Lucie
    A buddy of mine said that if you take the atomizing part of a spray gun tip off, and spray low pressure itll sling big drops. Never tried but......
    Not wanting to undo something I've screwed up, I'm looking hard @ this > http://www.tcpglobal.com/ZOL-20-45-1.html#.XGcvTtF7lTZ
    It will look Ok in the Glaspar, They have a bunch of colors.
    Slippery when wet?
  14. #12
    Dec 2011
    Thanks again for everyone's input.If I decide to go that route I may build a simple "splatter" gun.
    Getting a little burnt out right now.Not sure if I want to take on a full blown color change of the interior.I like the current black,but got to thinking that a grey with orange spatter would give a newer cleaner look.
  15. #13
    Slippery when wet?
    Has some texture to it, pretty tuff.
  16. #14
    Jan 2007
    Amityville/Lindenhurst
    for drops, almost no pressure, full fan, heavy on the material
    it will spray drops. no need to shoot it upside down.
    be cautious when using gelcoat if you dont mix properly and get enough on you wont have the volume for it to cure totally tack free
    for webbing - use the webbing additive it works great for that and much easier to control then flicking a brush.
    personally I dont like splatter, too old fashioned and busy even for an older boat but if thats your vision- go for it
  17. Thanks outasite thanked for this post
  18. #15
    Jun 2001
    did this a few years back with a modified paint brush and a little practice....
    Attached Thumbnails Attached Thumbnails Inside splash cvoat2.jpg   Inside splash coat.jpg
  19. Thanks outasite thanked for this post
    Likes NICE PAIR liked this post
  1. Who make super tough hard coat hyd jackplate for rough water use
    By LOSTINJ in forum Technical Discussion
    Last Post: 04-23-2016, 07:53 AM
  2. Paint Or Gell?
    By Maple Leaf in forum Fiberglass and Composites Discussion
    Last Post: 05-24-2009, 10:39 PM
  3. gell coat
    By wpahl_2 in forum Fiberglass and Composites Discussion
    Last Post: 06-19-2008, 12:02 PM
  4. Splatter Painting
    By Riverman in forum Appearance Mods
    Last Post: 01-03-2008, 09:39 PM
  5. Paint or gell the hull
    By Euroski in forum Appearance Mods
    Last Post: 02-27-2005, 10:44 PM
