Results 1 to 4 of 4
    Jul 2010
    Oak Harbor WA
    Looking for a CLE housing
    Like the tittle says looking for a CLE housing. Tired of touching up the peeling on my bobs LWP. Let me know what you got. Thanks in advance David.
    ft pierce fl
    I have a new 2 hole cle. It is a odd lower. the part number shows to be a left hand rotation with no neutral. Skeg is a rt hand wedge case. It was for sale on scream a couple years ago. Seller advertised it as left hand and no neutral. I looked at the pics and seen the tapered skeg. also seen a splined shift shaft. So i texted seller i want it. Now this is where my lack of logic shows. Seller text back and ask. "You know this is left rotation non shiftable lower" I said i see the tapered skeg and shift shaft so i want anyway. Now the real kicker is i have no boat or any 2.5 motors to put it on no matter which way it rotates. I buy it and it gets delivered. And hard to believe it rotates left when i turn the top shaft the rotation of a motor. Some would stop here and say good thing i dont have a boat or a motor to put this on. My next move was to order 200 dollars worth of tools and dig in. What i found is it is in fact a rt hand lower. Merc made a spacer to put in place of forward gear. the spacer is thick enough to keep the clutch dog in tight into reverse gear. has bearing against spacer the same as it would be against forward gear. Only other change is the flipper that the splined shift shaft rotates to slide clutch dog is left out. Unneeded because spacer keeps clutch tight against reverse gear. All new never run. 900.00 plus shipping.
    Jul 2010
    Oak Harbor WA
    Thanks for the offer but I found one already. Thanks again David.
    JUPITER, FLORIDA
    I have a clean empty CLE housing located in Florida.
    Attached Thumbnails Attached Thumbnails IMG_1064.jpg   IMG_1063.jpg   IMG_1066.jpg
    J-Town Hot Boat Team
    Barracuda 188CCR/Suzuki 140
    Past Boats:
    Checkmate 2800SX/Twin Merc 250’s
    Checkmate Pulsare 2400/Verado 300
    Checkmate Starflite/Merc Pro XB250
    Canadian Edition Hydrostream AE-21/Merc 2.5
    Checkmate Pulsare 2100/Merc 225Xri
    Hydrostream Valero YT Bowrider/Merc 175
    Talon T-21/Mercury Racing 2.5 Carb
    Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
    Velocity 230/Mercury 454 Magnum
    Scout 172 Sportfish/Yamaha 130
    SeaRay F16 Jet boat/Mercury SportJet
    SeaRay 17' Seville/Merc I/O
  1. Xr6 housing
    By tcrabtree in forum Parts Wanted
    Last Post: 02-13-2014, 07:53 AM
  2. 3.0 Sportmaster Billet Seal Housing & Shift Shaft Housing
    By alli-runner in forum General Boating Discussion
    Last Post: 12-27-2010, 08:25 PM
