Results 1 to 4 of 4
Thread: Looking for a CLE housing
02-13-2019, 10:11 PM #1
Like the tittle says looking for a CLE housing. Tired of touching up the peeling on my bobs LWP. Let me know what you got. Thanks in advance David.
02-15-2019, 12:43 AM #2
I have a new 2 hole cle. It is a odd lower. the part number shows to be a left hand rotation with no neutral. Skeg is a rt hand wedge case. It was for sale on scream a couple years ago. Seller advertised it as left hand and no neutral. I looked at the pics and seen the tapered skeg. also seen a splined shift shaft. So i texted seller i want it. Now this is where my lack of logic shows. Seller text back and ask. "You know this is left rotation non shiftable lower" I said i see the tapered skeg and shift shaft so i want anyway. Now the real kicker is i have no boat or any 2.5 motors to put it on no matter which way it rotates. I buy it and it gets delivered. And hard to believe it rotates left when i turn the top shaft the rotation of a motor. Some would stop here and say good thing i dont have a boat or a motor to put this on. My next move was to order 200 dollars worth of tools and dig in. What i found is it is in fact a rt hand lower. Merc made a spacer to put in place of forward gear. the spacer is thick enough to keep the clutch dog in tight into reverse gear. has bearing against spacer the same as it would be against forward gear. Only other change is the flipper that the splined shift shaft rotates to slide clutch dog is left out. Unneeded because spacer keeps clutch tight against reverse gear. All new never run. 900.00 plus shipping.
02-15-2019, 08:35 AM #3
Thanks for the offer but I found one already. Thanks again David.
02-15-2019, 03:59 PM #4
I have a clean empty CLE housing located in Florida.
J-Town Hot Boat Team
Barracuda 188CCR/Suzuki 140
Past Boats:
Checkmate 2800SX/Twin Merc 250’s
Checkmate Pulsare 2400/Verado 300
Checkmate Starflite/Merc Pro XB250
Canadian Edition Hydrostream AE-21/Merc 2.5
Checkmate Pulsare 2100/Merc 225Xri
Hydrostream Valero YT Bowrider/Merc 175
Talon T-21/Mercury Racing 2.5 Carb
Sleekcraft ModVP Bowrider/Evinrude 225 Vindicator
Velocity 230/Mercury 454 Magnum
Scout 172 Sportfish/Yamaha 130
SeaRay F16 Jet boat/Mercury SportJet
SeaRay 17' Seville/Merc I/O
Xr6 housing
By tcrabtree in forum Parts WantedReplies: 0Last Post: 02-13-2014, 07:53 AM -
3.0 Sportmaster Billet Seal Housing & Shift Shaft Housing
By alli-runner in forum General Boating DiscussionReplies: 4Last Post: 12-27-2010, 08:25 PM
