Results 1 to 15 of 23
    Mar 2011
    Virginia
    SOLD. Super nice 225 Promax
    Mercury Racing 225 Promax with essentially a new powerhead. Engine was built with a new factory block, piston kits (WSM with 1.5mm rings), steel cage rod bearings, all new electrical components (regulators, stator, trigger & switch boxes). A32 ECU that was just serviced at Simon motorsports w/ a year warranty. New TDR reeds, injectors cleaned & flowed. All new cooling components - poppet valve, thermostats & waterpump. The engine has about 15 hours on it for break-in, testing and tuning. Factory Promax midsection, Alien Style Factory light weight cowls. Ratcheting 1.87 lower unit with welded Bobs cone lower water pickup and torque tab on skeg. Probably forgetting a bunch. The motor looks new and run great. A Promax I built that is identical to this one peaked at 242 HP on the dyno. The only reason I’m selling it as I just bought my old 280 back and something has to go. Motor can be demonstrated and installation is available. Trades-ins of similar Mercury outboards will be considered. $7800 Firm, Call or Text me (Mark) at 757-84six-897one.
ID:	430830Click image for larger version.
ID:	430831Click image for larger version.
ID:	430833Click image for larger version.
ID:	430834Click image for larger version.
ID:	430835Click image for larger version.
    Go Time
    26 Regulator twin 250 EFI
  2. Likes tux974, Frank Molé liked this post
    May 2001
    Indiana
    You have leak-down numbers?
    Mar 2011
    Virginia
    UPDATED COMPRESSION READINGS. Readings were taken with engine warm and throttle open. Also verified the readings with 2 different Snap-on compression gages. They didn't change much from the original cold readings.
    Leakdown was less than 4%.
    Compression
    1-145#
    2-144#
    3-149#
    4-148#
    5-148#
    6-144#
    Leakdown
    1- 3%
    2- 3%
    3- 2%
    4- 3%
    5- 2%
    6- 3%
    Go Time
    Mar 2011
    Virginia
    Back to the top. This powerhead is exceptionally clean and runs great. Built with all top shelf components. High quality piece.
    Go Time
    Mar 2016
    Anza, CA
    Fat shaft or small shaft lower
    Mar 2011
    Virginia
    Smallshaft
    Go Time
    Jul 2004
    Connecticut
    Quote Originally Posted by Go Time View Post
    242hp is spot on. We have tested two on the dyno. Nice piece for sure @ $7800
  9. #8
    Mar 2011
    Virginia
    Thanks Greg
    Go Time
  10. #9
    Mar 2011
    Virginia
    Back to the top. Come on...you know you want it.
    Go Time
  11. #10
    Mar 2016
    Anza, CA
    What charging system and flywheel does it have?
  12. #11
    Mar 2011
    Virginia
    The charging system is a factory 40 amp system but with the lighter factory red flex plate flywheel ( used on the early model 40 amp systems). The flywheel has been indexed. The engine is essentially stock with some minor component upgrades. And before anyone asks, the heads are factory stock, not cut. I do have some other heads available to the buyer.
    Go Time
  13. #12
    Aug 2015
    NE Tennessee
    Those are really great compression numbers for stock heads and block.
    Really nice package you got there....
  14. #13
    Mar 2011
    Virginia
    Updated Post #3 with recent hot compression numbers and verified gage.
    Go Time
  15. #14
    Sep 2013
    long island
    Stock from factory they should b lower no...?
    11757 btw lol
  16. #15
    Jul 2004
    Connecticut
    Compression
    1-145#
    2-144#
    3-149#
    4-148#
    5-148#
    6-144#
    Leakdown
    1- 3%
    2- 3%
    3- 2%
    4- 3%
    5- 2%
    6- 3%
    That is one strong Promax
  1. Allison XB2003 w/ Merc. 260 super nice.
    By Fear And Loathing in forum Hulls up to 20'
    Last Post: 07-22-2013, 02:12 PM
