Results 1 to 15 of 23
Thread: Super nice 225 Promax
02-12-2019, 12:53 PM #1
SOLD. Super nice 225 Promax
Mercury Racing 225 Promax with essentially a new powerhead. Engine was built with a new factory block, piston kits (WSM with 1.5mm rings), steel cage rod bearings, all new electrical components (regulators, stator, trigger & switch boxes). A32 ECU that was just serviced at Simon motorsports w/ a year warranty. New TDR reeds, injectors cleaned & flowed. All new cooling components - poppet valve, thermostats & waterpump. The engine has about 15 hours on it for break-in, testing and tuning. Factory Promax midsection, Alien Style Factory light weight cowls. Ratcheting 1.87 lower unit with welded Bobs cone lower water pickup and torque tab on skeg. Probably forgetting a bunch. The motor looks new and run great. A Promax I built that is identical to this one peaked at 242 HP on the dyno. The only reason I’m selling it as I just bought my old 280 back and something has to go. Motor can be demonstrated and installation is available. Trades-ins of similar Mercury outboards will be considered. $7800 Firm, Call or Text me (Mark) at 757-84six-897one.
Go Time
26 Regulator twin 250 EFI
tux974, Frank Molé liked this post
02-13-2019, 08:30 AM #25000 RPM
- May 2001
- Indiana
- 188
- 13
You have leak-down numbers?
02-13-2019, 09:12 AM #3
UPDATED COMPRESSION READINGS. Readings were taken with engine warm and throttle open. Also verified the readings with 2 different Snap-on compression gages. They didn't change much from the original cold readings.
Leakdown was less than 4%.
Compression
1-145#
2-144#
3-149#
4-148#
5-148#
6-144#
Leakdown
1- 3%
2- 3%
3- 2%
4- 3%
5- 2%
6- 3%Go Time
03-07-2019, 08:30 AM #4
Back to the top. This powerhead is exceptionally clean and runs great. Built with all top shelf components. High quality piece.
Go Time
03-14-2019, 05:21 PM #55000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
Fat shaft or small shaft lower
03-15-2019, 05:26 AM #6
Smallshaft
Go Time
03-15-2019, 05:34 AM #7Screaming And Flying!
- Jul 2004
- Connecticut
- 6,009
- 465
- 168
- 911
- 951
03-15-2019, 06:01 AM #8
Thanks Greg
Go Time
03-28-2019, 09:24 AM #9
Back to the top. Come on...you know you want it.
Go Time
03-28-2019, 09:55 AM #105000 RPM
- Mar 2016
- Anza, CA
- 229
- 7
What charging system and flywheel does it have?
03-28-2019, 02:24 PM #11
The charging system is a factory 40 amp system but with the lighter factory red flex plate flywheel ( used on the early model 40 amp systems). The flywheel has been indexed. The engine is essentially stock with some minor component upgrades. And before anyone asks, the heads are factory stock, not cut. I do have some other heads available to the buyer.
Go Time
03-28-2019, 04:06 PM #12
Those are really great compression numbers for stock heads and block.
Really nice package you got there....James H. W2F a V-King... Want 2 Fly a V-King
04-03-2019, 10:24 AM #13
Updated Post #3 with recent hot compression numbers and verified gage.
Go Time
04-23-2019, 09:28 AM #145000 RPM
- Sep 2013
- long island
- 376
- 7
- 9
- 39
Stock from factory they should b lower no...?
11757 btw lol
04-25-2019, 07:06 AM #15Screaming And Flying!
- Jul 2004
- Connecticut
- 6,009
- 465
- 168
- 911
- 951
Allison XB2003 w/ Merc. 260 super nice.
By Fear And Loathing in forum Hulls up to 20'Replies: 7Last Post: 07-22-2013, 02:12 PM
