Results 1 to 3 of 3
Thread: Temp gauge
    Mar 2018
    NJ
    Temp gauge
    I am looking to install a temp-gauge setup on my 98 200 efi. I have to drill and tap the head for the setup i have. Is there a Better choice of sensor Port/Starboard head for a more accuracy. As of rite now looking to locate sensor on top of head in front of stat. Thank you
    Sep 2017
    Ashland city tn
    Quote Originally Posted by tabme View Post
    Since no one has answered, I'll throw this out , I'm in process of doing temp guage to and I'll b drilling and tapping for sensor in top of head ,unless sumone has a better set up with stock senders, I'm curious as well
    May 2014
    Livingston, Louisiana
    I like using water temp reading over had temp, just my preference. Think it reacts sooner. Just note that water temp runs about 30 degrees cooler than head temp would , so when your reading info on temps it doesn’t get confusing. When running one sensor it’s usually put it in the higher starboard head in flat area right behind thermostat.( can do it in either, just if I had to pick it would be stbd). I like running 2, one in each head, just to be able to monitor stats to make sure no trash in them and that it’s gettting up to operating temp. You should see atleast 140 and up to around 145 at idle with water temp senders. It’ll run around 110 running on the poppet valve.
  1. Rpm gauge and temp gauge wanted
    By ndependent in forum Parts Wanted
    Last Post: 06-27-2017, 08:18 PM
  2. Mercury Tech: Fuel gauge, temp gauge and tach...
    By fierodough in forum Technical Discussion
    Last Post: 09-17-2014, 12:22 PM
  3. Replies: 2
    Last Post: 09-04-2014, 05:33 PM
  4. OMC v-4 temp gauge
    By 2fast4u2 in forum Technical Discussion
    Last Post: 05-31-2004, 09:52 AM
