Results 1 to 2 of 2
    Ramona Ca
    DFL coating necessary?
    I have a 280 with top pin pistons in it that Iím putting new rings on. My question is it necessary to recoat the pistons prior with DFL? Thanks
    Its entirely up to you. Yes I recommend it. DFL does two things. (1) Its a Dry Lubricant that prevents gauling/scuffing should you experience a lean condition. (2) It provides a 1500 deg thermal barrier to the piston skirts. The thermal barrier properties prevent heat from transferring to areas its not needed. This in turn helps increase HP. I redo Piston skirts all the time for my customers. Most also have the Tops done in 1800 deg ceramic to better enhance the Combustion and lessen heat transfer.
    With Tops done
Name:	Coated Wizzards.jpg
    Without Tops done
  1. Floor coating
    By mercnut in forum General Boating Discussion
    Last Post: 05-08-2018, 06:26 PM
  2. coating for aluminum
    By jerry1865 in forum Technical Discussion
    Last Post: 07-10-2010, 03:12 PM
  3. best floor coating?
    By hawk232 in forum General Boating Discussion
    Last Post: 02-15-2010, 09:10 AM
  4. Re gel coating
    By Fibertron in forum Fiberglass and Composites Discussion
    Last Post: 08-27-2003, 10:03 PM
Spinelli Props
