Results 1 to 2 of 2
    Feb 2018
    Santa clarita ca
    95' and 97' V8 Johnson gearcase difference?
    Can you run a 97' gearcase on the older V8 Johnsons. I'm running 95s on there now. The model numbers are different on the 95 and 97 but all the part #s are the same. Just seeing if anyone has done it or knows if it bolts on and works.
    May 2001
    Hickory NC
    V8 units can be interchanged so long as both are same rotation.
  1. Verado HD 5,4 dia vs standard 4,8 dia gearcase - speed difference
    By Toffen in forum Props, Setup, and Rigging
    Last Post: 03-24-2015, 09:59 AM
  2. OMC Tech: Difference magnum vs lightning gearcase
    By CALVIN in forum Technical Discussion
    Last Post: 09-17-2013, 05:47 AM
  3. 4,88 diameter gearcase vs 5,44 diameter gearcase speed difference?
    Last Post: 12-26-2012, 06:46 PM
