Results 1 to 6 of 6
Thread: Vst pump
02-11-2019, 05:45 AM #15000 RPM
- Mar 2002
- SW FLA
- 162
Vst pump
My pumps bad what's best way to replace pump
02-11-2019, 07:12 AM #2Supporting Vendor
- 11,838
- 163
- 11
- 795
Remove VST tank top , then remove and replace pump , pretty straight forward .
Are you sure your circuits to start your pump in your ECU hasn’t failed ? I sometime have to use a relay on some that has failed , I use a relay attached to pump to get power to the pump and I use the keyed switch hot purple wire to excite the relay , when key is turned on relay closes then pump starts .. Just a thought !
JayLast edited by Jay Smith; 02-11-2019 at 07:17 AM.
Jay @ JSRE
02-11-2019, 07:48 AM #3Screaming And Flying!
- 14,753
- 381
- 1305
- 5602
- 11033
Jay are there any other good options for an elec pump replacement part on the stock 2.5's (other than merc ) worth messing with?
Have seen some on e- bay and was dubious about quality.
02-11-2019, 09:21 AM #45000 RPM
- Mar 2002
- SW FLA
- 162
Thanks for the reply pump has 12 volts I added 12volt battery power still nothing reversed leads to maybe spin backwards still nothing is there a part # for replacement internal vst pump.Thanks Jay
02-11-2019, 09:40 AM #5Supporting Vendor
- 11,838
- 163
- 11
- 795
I have folks ace the VST and go with a 260 style pump and return system , cleans that side up but pricey , Dunno pump part number sorry , and dunno if there is a generic pump that’s a direct bolt on ???
JayJay @ JSRE
02-11-2019, 11:50 AM #6Member
- Jul 2018
- Bonneau beach SC
- 52
- 15
12v is always on the positive lead to pump, ecm provides the ground
to complete the circuit.
Trim Pump or Jack Plate Pump Mounting Plates, Solenoids and Harness
By Onetime in forum Misc. Parts and AccessoriesReplies: 8Last Post: 09-10-2021, 08:35 PM -
Rigging Accessories and Parts (Mercury Race Trim Pump, Fuel Pump, Steering, ETC)
By kcoleman10 in forum Misc. Parts and AccessoriesReplies: 7Last Post: 11-26-2013, 08:58 PM -
mallery fuel pump, why does it have a small fitting on bottom of pump?????
By camaro7081 in forum Technical DiscussionReplies: 9Last Post: 05-25-2007, 09:16 PM
