Results 1 to 13 of 13
    Dec 2018
    Charleston, SC
    1988? Mercury 175 Black Max
ID:	433576Click image for larger version.
ID:	433577Click image for larger version.
ID:	433578Click image for larger version.
    I wanted to know if there is any interest in this motor. I bought the boat last summer. The boat was always used in fresh water, but I took it out in the ocean 4 times. I thoroughly flushed and rinsed the motor. The title and the guy I bought it from says it is a 1984, but the serial number is coming up as a 1988. Serial-0B384005 Model-1175412BD It is not the prettiest thing to look at, as you can see from the pictures. The motor runs pretty good. It does turn off sometimes when idling under load, and the RPM's float around at slow speeds. I have a few extra things controls, oil tank, oil, service manual, the prop, etc. $600.00
  2. Likes Bradwilliamson80 liked this post
    Mar 2017
    Moncks Corner
    might be interested for the right price..
    Dec 2018
    Charleston, SC
    $900.00 I will haul the boat to Moncks Corner if you have some way to lift the motor off. It comes with the controls and cables (not the steering cable), 2 gallons of unopened synthetic Quick Silver oil plus about one in the tank, SEI water pump kit, service manual, and prop. Thanks for your interest.
    Mar 2017
    Moncks Corner
    Is this the motor that was listed on craigslist for $375.00 in December?
    Dec 2018
    Charleston, SC
    No, I have not listed it on craigslist yet.
    Feb 2007
    Western Washington State
    In the vid you provided it looks like you aren't getting an accurate comp reading because the throttles aren't opened up. Any idea of # of hours this has on it?
  8. Thanks SC843 thanked for this post
    Dec 2018
    Charleston, SC
    Yea, I should of had it open. I will try it again when I get time. I don't have any idea how many hours are on it. Is there any way to tell?
    Jan 2019
    SC
    Is it a 2.4?
    Dec 2018
    Charleston, SC
    I am pretty sure it is, but not 100%. I can't find where they made any other sizes. Can you tell from the serial or model number? I can take pictures of anything on the motor that might answer your question.
    Dec 2018
    Charleston, SC
    Thanks for your advice. I rechecked the compression with the throttle open, and it raised the readings. The motor is no longer for sale.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by SC843 View Post
    That's odd ,, always drops a little
  14. #12
    Dec 2018
    Charleston, SC
    The originals were between 100-110, and with the throttle open they were between 110-120. Maybe I turned the motor over a few more times. The strange thing is there is no direct relationship between the first and second test.
  15. #13
    Sep 2017
    Ashland city tn
    Guage? Try a diff one if possible
  1. 1988 Mercury Black Max 150 Regulator
    By jmosselli in forum Electronics, Audio Systems, and Wiring
    Last Post: 09-26-2018, 03:58 PM
  2. 1988 Mercury Black Max 150 hp
    By 90eddie in forum Outboard Engines
    Last Post: 02-20-2016, 08:26 PM
  3. Mercury Tech: 1988 200 mercury black max (oil injected) idle problem
    By jaker88 in forum Technical Discussion
    Last Post: 05-21-2013, 09:18 PM
  4. Mercury Tech: 1988 Mercury black Max
    By blackmaxman in forum Technical Discussion
    Last Post: 07-18-2011, 08:47 PM
  5. 1988 Mercury XR4 Black Max 150
    By Rebel9921 in forum Technical Discussion
    Last Post: 12-07-2008, 12:16 PM
