Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
    Mar 2017
    Miami, FL
    Help Identifying a Mercury I bought
    I bought this motor and was told it was a 2.5 200 carb motor. I can't find the serial number for the motor.
    Build Stamp is 4-28-94
    I can't tell if the block stamp there says AA or AA with an F there, not too sure really. Just trying to figure out what I have.
    Any tips on what to look at? It is sitting on a different mid so that's of no help either. Want to know if it is worth rebuilding.
    Ft. Lauderdale, Fl
    should be a welch plug on top with a serial number
    Mar 2017
    Miami, FL
    Unfortunately it must’ve been replaced at one point. Nothing on the Welch plug
    Aug 2015
    NE Tennessee
    If it were mine, I'd pull a head and measure the ports....If your gonna build it, it's coming apart anyway.
    Sep 2017
    Ashland city tn
    Ya seems to me u have a merc replacement block and ole mother merc didnt always stamp em , can u post a pic of the block?
    Mar 2017
    Miami, FL
    I’ll get some pictures of the block. It could be a replacement block. I’ll measure the port height as well
    Mar 2017
    Miami, FL
    Took a few more pictures of the block and other parts.
    Sep 2017
    Ashland city tn
    Block sure looks like 2.5 to me
    O and next guess is #1 went lean from carb or lectrics
    What's the measurement across cyl?3.5?
    Sep 2017
    Ashland city tn
    And that aaf on block little weird to, usually just 2 letter
    Mar 2017
    Miami, FL
    I was hoping it was an FF block. You can see where it said FF, The First F is barely visible under the first A, but then it looks like someone went over it with the AA which is interesting.
    And Cylinder #1 definitely looks like it went lean.
    Sep 2017
    Ashland city tn
    If it went to merc they mite had put the aa sleeves in it or sumthin , would cause for the stamp but idk, did u measure piston?
  12. #12
    Mar 2017
    Miami, FL
    Quote Originally Posted by Merc 2.5 View Post
    I am going to pick up a Caliper to measure the bore and port height. What is the AA sleeve?
  13. #13
    Sep 2017
    Ashland city tn
    They mark blocks. Ff, aa etc, guess it's the sleeve in blocks that are different
  14. #14
    Feb 2013
    mt holly,nc
    rotate and see if the exhaust port has relief notch in it
  15. #15
    Waretown, NJ
    That is going to be a 2.0L 150. Bores look to be smaller than 3.500"
    WMH-31 are 150 carbs.
  16. Likes W2F a V-King liked this post
  1. Help with identifying a Mercury powerhead.
    By Rob'Z in forum Technical Discussion
    Last Post: 03-11-2022, 07:33 PM
  2. Bought my first fast boat today, action 18 need efi identifying help?
    By tompearson in forum General Boating Discussion
    Last Post: 07-25-2015, 06:38 PM
  3. Mercury Tech: Help identifying Mercury
    By riverrat321 in forum Technical Discussion
    Last Post: 10-15-2012, 08:58 PM
  4. OMC Tech: bought pig in poke lower unit need help identifying
    By rebible in forum Technical Discussion
    Last Post: 08-24-2012, 11:20 AM
  5. Identifying Mercury V6s
    By AxisMoto in forum Technical Discussion
    Last Post: 06-06-2005, 08:27 PM
