Results 31 to 45 of 50
  1. #31
    WI
    Agreed..... Mr. Carson is not somone I would worry about getting an issue resolved, he's the best!
    I have a boat or two.... that I never get to drive
  2. #32
    Every front half I’ve cut we had to cut that boss off the #1 for clearance. If you can shim the cage so it’s angled a bit down might fit.
  3. #33
    May 2016
    Holden Beach NC
    Would would it do for a stock V6 OMC 200 Looper like mine, Chris? Any advantage?
    Boats are like Potato Chips..You can't have Just One1
    1974 Hiliner Gypsy 260 Volvo SX
    1972 Hiliner Adventurer CC 200 Evinrude OceanPro
    1994 Sea Nymph 1462 25 Evinrude
    1989 Boston Whaler 13 w/40, then 50 Johnson (sold)
    1970 Wellcraft V-20 Steplift, Evinrude 155 Commercial (sold)
  4. #34
    Aug 2011
    Lake Mälaren, Sweden
    Quote Originally Posted by Gorilla0178 View Post
    I just got a set for omc. They are really nice. Beautifully cut and look to fit perfect.
    I’ve experimented a lot with stuffers on my looper motors. They definately give you a seat of pants gain, a least when it comes to instant off idle throttle response. A more crisp looper compared to the sometimes sluggish sensation when you bury the throttle going in gear (pulling skiers etc)
    Looks great Chris! Do you think I could modify these to fit the older type intakes I am using?
  5. #35
    Sep 2006
    Key Largo, Fl
    [QUOTE=Captain75;3113002]I’ve experimented a lot with stuffers on my looper motors. They definately give you a seat of pants gain, a least when it comes to instant off idle throttle response. A more crisp looper compared to the sometimes sluggish sensation when you bury the throttle going in gear (pulling skiers etc)
    Looks great Chris! Do you think I could modify these to fit the older type intakes I am using?[/QUOTE
    We'll see.When I first started the looper stuffers I assumed the large(late) diamond intake would be the best to go with,most common and I thought best intake tract.Am I wrong?I'm not being the least sarcastic,and obviously haven't studied them enough.After sealing the crankcase chamber on the front half and cc'ing # 1 and #2 I have found the interferance area in #1 displaces 9 cc's,the present stuffers displace a little over 7 cc's,so leaving the stuffer off #1 will actually help balance the front half.However,to get the chambers close the 23 cc tunnels on #3 and#5 leading to the center main bolt need to be filled...I'm planning on working on that next month,as time provides.
    As to the other intakes,I found two more designs,the teacup that uses the same 6 petal cage as the diamond I thought was best,and a diamond type that mounts the 5 petal aluminum cage,which has a smaller (narrower) reed cage and intake slot to match.The present stuffers could not be modified to use in the 5 petal intake/cage setup.
    The teacup style,with the 6 petal cages, would accept the present stuffers with some modification to the stuffer,due to the footprint of the cage was milled a few thousandths to insure a flat seat for the cage.The whole pocker could be touched up on the mill,or the stuffer trimmed a little to fit.
    The plan was to provide a drop-in part,not needing modification,I missed the mark a bit on that,being spoiled by the great results with the Merc counterparts.I need to be more through,and will,as time allows.
    At present time,the stuffers we have will fit nicely in 2-6,where they do the most good,only modification probably needed will be 020-030 filed from the bolt bosses on the ends of the cages.This could be remedied by using 065 thick stuffers instead of the present 095,but a third of the benefit would be lost.I look forward to your feedback,and will send you stuffers to work with for your input,give a call,305-394-3354,Chris
  6. Likes Merc 2.5, SS Minnow liked this post
  7. #36
    That's why he's the professor ...
  8. #37
    Aug 2011
    [QUOTE=Chris Carson's Marine;3113009]
    Quote Originally Posted by Captain75 View Post
    Sounds great Chris!
    I will give you a call. Just have to find the right moment since I have night when sun is shining in fla...
    I agree no1 is a bit tricky due to limited space and the sharp bend.
    //Anders
  9. #38
    7 Post(s)
    Chris do you have pricing for the OMC's yet?
    BTW, every stuffer Ive ever used has needed fitting to work.
    Remember too that the reed stop also fills crankcase volume.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  10. #39
    Sep 2006
    Key Largo, Fl
    65$ for the set of 5,serving cyls 2-6.Havent worked out the main bolt channels yet,but a cork trimmed properly with a smear of epoxy over it will suffice,Chris
  11. #40
    7 Post(s)
    I use a plastic rod the diameter of the bolt access bore, cut to the angle of the case.
    A 12” rod will make a bunch of the them.
    I keep spares in my tool box.
    Friction fit, they tap right in.
    For removal, I drive a drywall screw part way into it, hook a hammer to it and pry (against a slab of wood) it out.
    I clean em up an reuse em over and over.
    Let me get a count and I’ll have an order for you Chris.
    Quote Originally Posted by Chris Carson's Marine View Post
  12. #41
    7 Post(s)
    I should add:
    Ive cut a bunch of cases but dont remember having interference issues???
    Probably, all were w/aftermarket reeds w/no stops.
    I remember them being close but dont remember contact.
    My 3.3 is cut .100".
    What Chris is doing is different though.
    W/o counting, Im probably at 3 sets.
  13. #42
    Sep 2006
    Key Largo, Fl
    Without the stops I think they will all fit,providing you trim the cage bolt bosses for clearance in the front half,no problem if you want sets if 6...but the #1 intake chamber is around 9 cc's smaller,so leaving the stuffer out will help balance it out.Where do you find the plastic rod,I was preparing to order delrin 1 in rod...a little overkill I think,Thanks Gary,Chris
  14. #43
    7 Post(s)
    Interesting on intake volume differences.
    I never CC’d them but should have.
    I think the 1” rod came from mscdirect.com
    Attached Thumbnails Attached Thumbnails 5B36C90F-E72D-4E70-B750-B158A5157D7A.jpg
  15. #44
    Sep 2017
    Collingwood Ont. Canada
    Quote Originally Posted by Schramer View Post
    Mistakenly got charged for another set of reeds,called and spoke to Chris. He was willing to refund immediately,but had him ship a set for another build i was doing.
    Recommend his services and products 100%.
  16. #45
    Aug 2011
    I use a wooden dowel. I cut a piece off a broom shaft at an angle that correlates with block structure. Fits perfekt and swells into a snug fit.
    Chris, you could probably make one for cyl#1, but I think It should be shaped to create a downward angle.
  1. Can you replace a mercury inline 6 crankcase cover?
    By merc1250bayliner in forum Technical Discussion
    Last Post: 02-07-2019, 06:47 PM
  2. Mercury 2.4 200 Block and Crankcase
    By RocketMan in forum Misc. Parts and Accessories
    Last Post: 06-17-2015, 08:47 PM
