Results 1 to 7 of 7
    Jul 2009
    gatineau qc, canada
    matching aluminum filler/epoxy colour.
    hi all,
    i want to try something out on my sportsmaster but to do so, i'd like to find some epoxy filler that matches the bare aluminum colour as close as possible. obviously, it needs to be strong enough to hold up the pressure and heat of surfacing the case. anny suggestions? links?
    thanks
    1998 charger stv. 225 promax. -sold-
    1993 22 talon. 2016 yamaha 200 SHO, nizpro tuned
    Pekin, IL
    There is a product called "All Metal" which is like a bondo type filler made of metal. Tough stuff and is similar in color to the Sporty however nothing is going to match perfectly.
    Rock
    Team Junk
  3. Likes specboatops, XstreamVking liked this post
    Jul 2009
    gatineau qc, canada
    thanks. yeah i realise i wont get a perfect match. just want to know whats out there!
    Pekin, IL
    Don't think you will do better than All Metal as the metal used in the product is aluminum. Best of luck.
    Rock
    Team Junk
  6. Thanks mistah_max thanked for this post
    Belgium
    Loctite has a similar product.
    I made blow out ring on my cle with it in spring. Still looks like day 1. When its hardened it darker than ally. Once you sand it the particles shine through and its very similar.
    I have some small imperfections on my unit and will repair them with this stuff.
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  8. Thanks mistah_max thanked for this post
    Feb 2005
    seattle
    wes tex has a gray color whick should be close. ive used it for years.
    Mar 2009
    Saint Lucie Florida
  1. Advice needed for filler and epoxy primer
    By Mr. Demeanor in forum Fiberglass and Composites Discussion
    Last Post: 08-07-2016, 06:23 PM
  2. WTB: OMC v4 Epoxy-in filler blocks
    By vintage v4 in forum Parts Wanted
    Last Post: 04-20-2016, 07:48 PM
  3. pc7 epoxy filler tips needed
    By NosBoss in forum Technical Discussion
    Last Post: 03-03-2015, 10:31 PM
  4. Epoxy or filler for exhaust chest ?
    By olboatman in forum Technical Discussion
    Last Post: 12-22-2014, 04:22 PM
  5. Lower Unit Epoxy Filler
    By C/E in forum Technical Discussion
    Last Post: 06-22-2004, 08:52 AM
