Results 1 to 10 of 10
Thread: Johnson 110 V4 general Questions
02-05-2019, 07:54 PM #1Member
- Jul 2013
- Ga
- 32
- 9
I have a 87 Johnson 110 V4 Bubble back and I don't see many on the web..I have a some question about this outboard.
What was the logic behind the Johnson 110 V4 vs The 90, 100, 115, 120 other than the obvious HPs
What can I expect from this outboard such as performance, reliability, fuel usage ( I know it depends on the condition of the outboard and how it was used, compression ect)
I have read that the prop rated HP on the 110 is 110?
I have also read that the 110 is like having a 140?
Were the 110 V4 a popular outboard in it's day and what about this time almost 30+ yrs later?
Is the 110 V4 an engine that is or can be used for high performance building?
I'm sure I will come up with some more questions at some point, however these are the ones that pop into my head at the moment.
any other additional information you members can pass along in this thread would be appreciate it?
02-05-2019, 08:21 PM #2Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
140 was the old system of powerhead rated
it lost some compression etc to run on low quality fuels and ended up as 110 prop rated
HaulNbass liked this post
02-06-2019, 08:48 AM #35000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
find some old hi comp 140 heads and 1 3/8" carbs and it's the same motor as an old 140...good , cheap , simple motor...
02-06-2019, 06:55 PM #4Member
- Jul 2013
- Ga
- 32
- 9
02-06-2019, 06:59 PM #5Member
- Jul 2013
- Ga
- 32
- 9
02-06-2019, 08:47 PM #6Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
So, here is what I have gathered in my beers of research.
About's the mid eighties, there was a standardization of confirming how much hp an outboard produced. And it then became an industry standard, maybe a law, that horsepower rating would be measured at the prop shaft, not at the crank. Rumors are that a certain manufacturer would fudge the #'s but again, probably rumors.
So, even with those laws in place, a certain manufacturer was said to have fudge those numbers slightly, so a few years after that, a new industry standard, maybe a law or regulation, was created stating that the advertised horsepower rating had to be accurate within (not sure here again) 10-15%.
Hopefully that explains the hp rating a bit. Beyond that, there are many here with much info. Good Luck to you!
02-07-2019, 06:11 PM #7Member
- Jul 2013
- Ga
- 32
- 9
I have read this somewhere on the web and it makes sense to me and I understand it. I also can see that this can get very confusing for someone like me that the way Johnson has gone about creating all those models with the 88, 90, 105, 110, 112, 115, 120, 125, 126, 130, 132, 135, 140 and so on
02-07-2019, 08:28 PM #85000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
The big carbs and hi comp heads are getting a bit harder to find but there should still be plenty around ..put a post on parts wanted...
as far as hp ratings , I think OMC pretty much used it as a designation number more than actual hp rating...for example, 88 spl was a 90 without VRO...
your 110 is a detuned 140 pretty much ...same block and exhaust with low comp heads and smaller carbs...
02-08-2019, 12:16 AM #9
The propshaft rated 110 you have ('87) is close to the old 140 crankshaft rated ('78 ish). you can put the higher compression heads on yours and get a few more out of it.... the 1 5/16 carbs will do for heavier boats and the 1 3/8 are for lighter boats..... (think holeshot....) now, don't confuse the looper 120, 130 and 140 since they are a different animal all together; they are all propshaft rated.
02-10-2019, 02:34 PM #10Member
- Jul 2013
- Ga
- 32
- 9
General Impressions of a 1999 Johnson 225 HO
By BigBrud1958 in forum Technical DiscussionReplies: 7Last Post: 03-09-2015, 06:00 PM -
Mercury Tech: '05 Opitmax 250xs general questions
By gregpro50 in forum Technical DiscussionReplies: 3Last Post: 07-27-2012, 06:16 AM -
general questions
By DAD2DTCC in forum The Scream And Fly LoungeReplies: 11Last Post: 04-10-2009, 02:43 PM -
OMC general questions.
By HydraSports in forum Technical DiscussionReplies: 11Last Post: 02-08-2008, 11:49 AM -
2000 300PM general Questions
By 300Procraft in forum Technical DiscussionReplies: 4Last Post: 01-11-2005, 10:29 PM
