Results 1 to 5 of 5
Thread: 150 Optimax
    Johnson City TN
    150 Optimax
    This motor came to me as a basket case, the previous owner had it disassembled due to a knocking sound. The repair shop didn’t see a problem and owner ended up buying another motor. Turned out to be a bad lower unit. I got the motor and ,after checking the bores and clearances, replaced the rings, rod bearings, and gaskets/o rings. I also cleaned the injectors and fuel rails and VST. Lower unit was replaced. Motor had 272 hours at rebuild and has 345.9 hours now. Pushed my Ranger 390 to about 60 with a 23” Tempest prop. Motor runs great, selling due to buying a new 150 4 stroke.
    2.5 liter, 20” shaft, 1.87:1 gear ratio, approx 440 lbs. motor has Mercury water inlet kit #17280A2 installed on lower unit. Includes boat mounted oil tank. I had the motor put on DDT at local dealer and included pics of the readout of hours and RPM range use.
    Thanks for looking!
    $3200
    can ship if buyer pays and arranges freight
    Bryan
    423two five four 0371
ID:	430168Click image for larger version.
ID:	430169Click image for larger version.
ID:	430170Click image for larger version.
ID:	430171Click image for larger version.
ID:	430172Click image for larger version.
    Jul 2011
    Lake Lanier, GA
    I’m interested. Rigging and controls included?
    Johnson City TN
    No controls, just oil tank
    thanks
    Feb 2017
    Indiana
    Pm sent
    STV Pro Comp, 225 Promax
    Allison GS 225 ProMax. Sold
    Advantage Banshee e-tech 300 w/ Sport master. Sold
    Johnson City TN
    Sold
    Thanks
  1. 1999 200 optimax or 2004 250 xs optimax?
    By vmax80096 in forum Technical Discussion
    Last Post: 07-26-2018, 12:34 PM
  2. Mercury Tech: Optimax to non Optimax lower
    By btown101 in forum Technical Discussion
    Last Post: 07-11-2018, 01:41 PM
  3. Will 225 Optimax ECU on my 200 Optimax give it more HP?
    By paragod in forum Technical Discussion
    Last Post: 11-27-2017, 05:18 AM
  4. 135 Optimax Vs. 150 Optimax
    By Surfhunter in forum Technical Discussion
    Last Post: 02-24-2008, 02:47 AM
