Results 16 to 25 of 25
Thread: Air filter on carb setup?
02-02-2019, 10:03 PM #16
02-02-2019, 10:33 PM #177000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Thank you bullet20vee, I should have a couple pullover tubes on the way soon.
02-02-2019, 10:39 PM #185000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
I found 3 of them. They will be on the way to you Monday AM. Hope they help you out.
02-03-2019, 06:44 AM #19Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Those will change how carb meters. Due your carbs have an adjustable idle mixture? If so they are original 96 and newer. Running these without air box changes metering but not like the earlier ones that needed 11 size change these will need less but you will need to jet up. IMO start about 6 up and work back down, personally leave box on.
02-03-2019, 07:29 AM #207000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
No. The idle is a jet. It doesn't have the adjust screw like the 99 225 ocean pro that's at my shop has. It has 2 Jets. I can check sizes if that helps. Like I stated, I believe it was tuned my Monty with the airbox on. The motor I have is pieced together. Not sure what year any of it is. Midsection and cowling are 99, that's all I know..
02-03-2019, 07:30 AM #217000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ahhh I hate the box.
02-03-2019, 12:54 PM #227000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Took it out today. Had issues. Not cause of the filters I don't think. I took them off and put the box on. It dies every time I tried to accelerate from idle. It's time to pull the carbs off and rebuild them. Gonna look at the reeds too. Not sure what was up. I did over fill the fuel tank I think. None came out of the vent. But it was full as it could be. Not sure if that could cause anything. I pulled 5 gal out and now there is some air space. Not much but some.
02-04-2019, 08:53 PM #235000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
Have you done the linc and sync precedure EXACTLY as it states in the service manual without skipping any steps? I found that to be the best way to eliminate any issues after doing a leakdown test, checking fuel delivery to the carbs from the pump, making sure you have proper fire to all the plugs with a spark tester (3/8" gap), fresh fuel, etc. My looper went stupid on me one time and the only thing I found wrong was the timing roller arm had gotten out of adjustment. If I feathered the throttle and allowed it to slowly climb the rpm range, it would run good on the top end. If I stabbed it out of the hole , it would just die.
02-04-2019, 09:11 PM #247000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
I'll be sure to do that when it's back together.
02-10-2019, 06:28 PM #255000 RPM
- Sep 2011
- Deplorableville
- 740
- 1347
- 76
- 3211
- 1452
Did your stuff show up last week? Hopefully it made it there okay.
six carb setup
By Chaz in forum Technical DiscussionReplies: 53Last Post: 05-04-2016, 06:32 AM -
Mercury Tech: Remove fuel filter setup?
By gmacrae in forum Technical DiscussionReplies: 5Last Post: 05-11-2010, 05:54 PM -
115 L6 Carb Setup
By 1FASTLASER in forum Technical DiscussionReplies: 1Last Post: 04-01-2004, 09:24 AM
