Results 1 to 5 of 5
    Jun 2009
    Leesburg, GA
    Suzuki DF175 Flush coolant passages?
    I picked up a 2013 DF170 to rebuild after it had a dropped valved destroy a piston. The engine is i fantastic shape other than the damage from the dropped valve and I am well on my way to sourcing all the parts needed to get it back running again. I have a few questions but the main one is about cleaning out what looks to be maybe salt deposits from the cooling passages. Is there a solution that I could run through the motor to dissolve the deposits? I saw where some guys run vinegar through the system for a while and it seems to work ok but is there anything that will for sure work? I do not think the deposits are all that bad, they are not blocking any passages or anything but with me freshening up this motor i would like to clean it as well as I can.
    1998 BackCountry 201 Proguide, 250xs
    Feb 2014
    Missouri
    Acidic acid / vinegar is supposedly bad. If it is salt you can steam or flush with water.
    Hardwater stains media blast or run the acids. Clr, vinegar ect.
    Jun 2009
    Leesburg, GA
    OK, I guess if it is just salt build up running hot water through it would break it down and clean it up. I scrapped some of the buildup from inside the water passage and tasted it. and it was salty but not like table salt or anything. I guess it may be a mixture of minerals as well as salt.
    Rhode Island
    Boiling water. If you have a tank big enough to boil the block in, over a bonfire?
    That'll do the trick. Otherwise, find some place that does galvanizing - they have hot acid baths.
    Your last option is manually scrape away what's there, and call it a day. The rest will usually dissolve on it's own through usage and proper wash-downs.
    Feb 2017
    Naples FL
    I had pretty good luck with CLR after letting it soak in for awhile. Acid works FAST!
  1. best way to clean out the coolant passages in a 2.5 block
    By ProComp in forum Technical Discussion
    Last Post: 07-22-2014, 06:11 AM
  2. Mercury Tech: 2.4 Coolant hose routing
    By dwiggl in forum Technical Discussion
    Last Post: 03-30-2010, 11:45 AM
  3. OT Auto coolant temp?
    By RSCHAP1 in forum The Scream And Fly Lounge
    Last Post: 03-05-2006, 10:20 AM
  4. fuel for coolant
    By Techno in forum Technical Discussion
    Last Post: 08-04-2001, 07:19 PM
