Results 1 to 5 of 5
02-02-2019, 02:29 PM #15000 RPM
- Jun 2009
- Leesburg, GA
- 364
Suzuki DF175 Flush coolant passages?
I picked up a 2013 DF170 to rebuild after it had a dropped valved destroy a piston. The engine is i fantastic shape other than the damage from the dropped valve and I am well on my way to sourcing all the parts needed to get it back running again. I have a few questions but the main one is about cleaning out what looks to be maybe salt deposits from the cooling passages. Is there a solution that I could run through the motor to dissolve the deposits? I saw where some guys run vinegar through the system for a while and it seems to work ok but is there anything that will for sure work? I do not think the deposits are all that bad, they are not blocking any passages or anything but with me freshening up this motor i would like to clean it as well as I can.
1998 BackCountry 201 Proguide, 250xs
02-05-2019, 08:47 AM #26000 RPM
- Feb 2014
- Missouri
- 1,212
- 66
- 12
- 83
Acidic acid / vinegar is supposedly bad. If it is salt you can steam or flush with water.
Hardwater stains media blast or run the acids. Clr, vinegar ect.
02-06-2019, 11:16 AM #35000 RPM
- Jun 2009
- Leesburg, GA
- 364
OK, I guess if it is just salt build up running hot water through it would break it down and clean it up. I scrapped some of the buildup from inside the water passage and tasted it. and it was salty but not like table salt or anything. I guess it may be a mixture of minerals as well as salt.
02-12-2019, 06:30 PM #4
Boiling water. If you have a tank big enough to boil the block in, over a bonfire?
That'll do the trick. Otherwise, find some place that does galvanizing - they have hot acid baths.
Your last option is manually scrape away what's there, and call it a day. The rest will usually dissolve on it's own through usage and proper wash-downs.1) 1995 14' Bayliner Restoration <--Click
2) Home-Made Tunnel-Boat Project <--Click
02-20-2019, 09:23 PM #5Member
- Feb 2017
- Naples FL
- 74
- 27
- 9
I had pretty good luck with CLR after letting it soak in for awhile. Acid works FAST!
best way to clean out the coolant passages in a 2.5 block
By ProComp in forum Technical DiscussionReplies: 5Last Post: 07-22-2014, 06:11 AM -
Mercury Tech: 2.4 Coolant hose routing
By dwiggl in forum Technical DiscussionReplies: 1Last Post: 03-30-2010, 11:45 AM -
OT Auto coolant temp?
By RSCHAP1 in forum The Scream And Fly LoungeReplies: 2Last Post: 03-05-2006, 10:20 AM -
fuel for coolant
By Techno in forum Technical DiscussionReplies: 1Last Post: 08-04-2001, 07:19 PM
