Results 1 to 14 of 14
Thread: Stiletto Thrust washer
02-01-2019, 04:50 PM #15000 RPM
- Mar 2013
- Sunshine Coast, Queensland
- 188
- 47
Gidday guys
I have been given an old Stiletto Advantage 2 propeller which according to the googling I have done, was made by Precision Propellers before Yamaha bought them out. It is splined for my Evinrude shaft but none of my Evinrude thrust washers fit it.
Can anyone advise what thrust washer to use?
I would like to try it on my 175 ETEC.
Thanks and regards to all.
02-05-2019, 05:16 PM #2
What size shaft/ how many splines ?
02-06-2019, 09:06 PM #3Team Member
- Lake Coochiching, Ontario
- 7,746
- 271
- 485
- 1570
- 6 Post(s)
A 175 Etec would be 1" 15 spline.
I still have a 13 spline Stiletto that I need to sell as I don't have a V4 anymore. My Stiletto worked with the same thrust washer as my Raker and SRX propellers. A Renegade took a different washer. But that was all 13 spline. It was a great prop for water skiing and ran a bit higher than advertised pitch.
02-09-2019, 01:17 PM #45000 RPM
- Jan 2008
- SUMMERVILLE S.C.
- 201
- 34
- 42
We sold many ,many of them old stilletos...the rubber hub props were brand specific , made to work with factory hardware...the splines may be the same , but the hardware won't work from brand to brand motors...if you have a merc or yamy prop ,it wont work on your evinrude
02-11-2019, 06:03 PM #55000 RPM
- Mar 2013
- 188
- 47
It's splined for Evinrude, slides on the shaft fine, just that my Evinrude thrust washers don't "land" on the back of the hub. The diameter of the hub is bigger than my thrust washers.
02-11-2019, 07:35 PM #67000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
What size is the recess that the thrust washer fits into?
02-12-2019, 08:07 PM #75000 RPM
- Mar 2013
- 188
- 47
02-12-2019, 09:17 PM #87000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
I have 2 thrust washers that are the right size. They measure 2.49inch. One is .5 inch thick and one is .75 inch thick. And I don't have any propellers that they go to. I got one with a prop I bought but it didn't go to the prop that I bought.....soooo. Your in Queensland? Australia? Your welcome to either one if you cant find one.
02-12-2019, 10:06 PM #95000 RPM
- Mar 2013
- 188
- 47
Mate, that would be fantastic. I will PM you.
02-13-2019, 01:44 AM #105000 RPM
- Mar 2013
- 188
- 47
Hey Gorilla, just tried to PM you back but apparently you are over your message limit and can't receive any more unless you clear some space.
02-13-2019, 06:02 AM #117000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ok I'll clear it
02-13-2019, 07:37 PM #127000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
One is 1/2 inch thick one is 3/4 inch thick. No numbers on them. The 1/2 inch one is flat on the back the other has a taper. The taper seems to be the same on All of them.
02-13-2019, 10:37 PM #135000 RPM
- Mar 2013
- 188
- 47
Thanks mate!
PMed you.
02-16-2019, 10:22 AM #14Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Good luck and hope it works out.
If not, somebody with a lathe near you?
Looking for Omc thrust washer and nut
By 1actionkw in forum Parts WantedReplies: 7Last Post: 03-21-2018, 05:29 PM -
Thrust washer
By Slow_Lavey in forum Props, Setup, and RiggingReplies: 6Last Post: 03-31-2012, 09:27 PM -
Thrust washer
By Robertrosen in forum Technical DiscussionReplies: 1Last Post: 03-17-2009, 08:52 PM -
Thrust Washer
By Richard in forum Technical DiscussionReplies: 0Last Post: 06-19-2007, 04:30 PM -
By illMATTic in forum Props, Setup, and RiggingReplies: 12Last Post: 03-20-2006, 01:07 PM
