Results 16 to 25 of 25
Thread: A little help across the pond
02-06-2019, 01:40 PM #16
who told you that ring 20 was built by Shakespeare ?
the hull design is almost ring, but the top is all ShakespeareLast edited by phillnjack; 02-06-2019 at 02:23 PM.
02-06-2019, 02:22 PM #17
that is a Shakespeare 6.0..
Good boats that go pretty well.
that one used to be down the south coast, Poole / Bournemouth area.. think I might have spotted it off studland bay a good few years back.
if it is the one I think I remember it can jump some serious waves.
check this page out for info about the boats....
http://www.boatmad.com/forum/f4/shak...ted-20146.html
02-07-2019, 03:54 PM #18Junior Member
- Jan 2019
- Manchester Uk
- 22
Thanks for the help identifying the boat! Looks like you might be onto something. Looking to make a screen similar to the one in that post actually
The second gasket has arrived, I'll tackle the job this weekend and report back with pictures
I've made a new loom from coils to switch boxes, used some high quality silicone wire. The stator will be replaced , it runs on muffs well but resistance readings differ and charging output non existent with some dodgy looking wires.
Does anyone know where a water pressure gauge can be plumbed in on the old 2.4 mercs?
Much appreciate the help
Chris
02-07-2019, 03:57 PM #19
Should b fitting top block behind flywheel in between heads kinda, if it has a hose goin to poppet just t into it
02-07-2019, 04:01 PM #20Junior Member
- Jan 2019
- Manchester Uk
- 22
It doesn't have a hose going to the poppet its the older style I think. From memory it has a large grub style screw in between the heads. Will take pics at weekend
02-07-2019, 04:03 PM #21
If dosent have his that's fine but it will have a place to access water jacket , I'll try find u a pic
02-10-2019, 01:31 PM #22Junior Member
- Jan 2019
- Manchester Uk
- 22
This weekend most of our effort have been focused on the hull. However this afternoon I lifted off the powerhead and started cleaning the gasket faces
I've noticed a little black residue around the bottom crank seal and it looks a little tired. Almost like someone attempted to remove and gave up. The housing it very slightly damaged, that doesn't concern me.
Is it worth me changing the seal now whilst the power head is off? It ran great on the muffs. My own experience with two stokes is little single cylinder bike engines.. A bad crank seal would play havoc with the mixture and the bike wouldn't idle... With it being a v6 could the problem be "hidden" in regards to the running symptoms?
It looks an easy job?
Pics will follow.
Chris
02-10-2019, 01:52 PM #23Junior Member
- Jan 2019
- Manchester Uk
- 22
02-11-2019, 03:22 PM #24Junior Member
- Jan 2019
- Manchester Uk
- 22
I've found a gasket kit super cheap online, has anyone had any experience with "morse" gaskets
ebay item number: 162369307441
https://www.ebay.co.uk/itm/3213-NEW-Morse-Mercury-Mariner-200-225-hp-Powerhead-Gasket-Set-Kit-FREE-Ship/162369307441?epid=516479166&hash=item25cdf70331:g:aHMAAOSwNnRYhqfK:rk:2f:0
Chris
02-11-2019, 04:03 PM #25
I had the same happen to mine. My driveshaft was full with oil.
Oil collects in the lower part of the block and than goes via the bleed lines to the top of the block where it lubricated the top bearing.
So I would have it fixed because the oil is just leaking through so your bearings dont get the oil they should.
21 skater on the big pond
By Esox4130 in forum Photos and VideosReplies: 13Last Post: 07-28-2017, 09:46 PM -
nascar in the pond
By XstreamVking in forum General Boating DiscussionReplies: 1Last Post: 08-24-2010, 07:52 PM -
pond hopping!!
By STVmod in forum General Boating DiscussionReplies: 0Last Post: 11-28-2008, 07:47 AM -
lost my pond
By moparbarn in forum Radio Contolled Performance BoatsReplies: 15Last Post: 08-24-2007, 03:22 PM -
foot pond
By lqdegl1 in forum The Scream And Fly LoungeReplies: 14Last Post: 09-10-2003, 09:38 AM
