Results 1 to 11 of 11
    Sep 2017
    Miami
    Mercury 150 four stroke / Allison Grand Sport
    We put the modified lower unit on, and tested it. The gas mileage is incredible. This was the first time out with the low water, nosecone, with some adjustments, 78 should be attainable. https://www.wavetowave.com/home/2019...on-grand-sport
    What hub kit? Stock hub or hi po?
    St. Cloud, FL
    Boat looks flat in the video. With that long nosecone on the gearcase, you should be able to safely go above the pad. Not sure the ProMax will be your best top end prop either. Great for loads and cruising, but to get all out top end, may want to try a larger pitched 3-blade. (Hoss, ET, etc)
    2006 Spectre 24' SCS
    2020 Mercury 300 ProXS
    2001 Allison XB2003
    2006 Mercury 250XS
    1988 22' Velocity (sold)
    1995 Allison Grand Sport (sold)
    1998 Mercury Stock 2.5-260 SS
    1990 Velocity 30' - 502's (sold)
    Go Daddy Go! Racing
  4. Likes pkstv, Michael J Giesler liked this post
    Sep 2017
    Miami
    Stock Flo torque 2 (Q6)
    Sep 2017
    Miami
    Quote Originally Posted by Ziemer View Post
    Read the article �� The Instagram video is just loafing along, holding my phone. I personally wouldn't run a three blade on it.
    St. Cloud, FL
    Quote Originally Posted by WavetoWave View Post
    I did read the article. Appears that you’re waiting on a trophy and you’re moving the engine up a hole on the plate. The trophy’s in a 26” pitch were great all around props on these hulls but the larger pitches for some reason didn’t work as well.
    Based on on your numbers the slip appears to be good as it’s in the 6%-7% range. (Think the first article said this engine had 1.92 gears).
    Curious on why no on a 3-blade?
    Are you running some counterweight on the passenger side? Don’t remember if it said in the articles. Little bit of height and little bit of pitch, I bet 80 is possible.
    2001 Allison XB2003
    2006 Mercury 250XS
    Go Daddy Go! Racing
  8. Likes WavetoWave liked this post
    Sep 2017
    Miami
    Ya, 1.92. I need to have a little more counter weight, only have 12 lbs there now. I prefer the 4 blades at that height. I'm almost sure 78 is in the cards. 80, possibly
    St. Cloud, FL
    I have a 25 lb bag that I use and run in the passenger gunnel when solo. I also changed my driver seat to slide sideways instead of front/rear.
    Good of luck chasing 80. That 150 is a great little motor. I drove one a couple years ago on a 19’ Tracker that would run an honest 65.
    2001 Allison XB2003
    2006 Mercury 250XS
    Go Daddy Go! Racing
  11. Likes WavetoWave liked this post
    Sep 2017
    Miami
    Thanks. Great idea with the seat slide.
    Oct 2005
    savannah,ga
    Good article. I wonder how much more you would see with a Pro XS?
  14. Likes WavetoWave liked this post
    Sep 2017
    Miami
    Quote Originally Posted by JBS View Post
    Me too, it would be great to test. I think it would be slightly faster. The only disadvantage it has is the slightly lower gears, 2.07:1.
  1. Testing the Allison Grand Sport with a Mercury 150 four stroke
    By WavetoWave in forum General Boating Discussion
    Last Post: 12-06-2018, 11:24 AM
  2. Grand Sport-Euro-SS2000-T4 w/conservative power? Possible 4 stroke?
    By Stoker1 in forum General Boating Discussion
    Last Post: 01-07-2006, 01:45 AM
