Results 1 to 8 of 8
    Mar 2007
    Ontario, New York
    Evinrude/Johnson Carbs (for various models)
    I've been cleaning out the shop and I have a ton of Evinrude/Johnson Carbs from 25-235hp. I have dozens of inline carbs ranging from the 1970's thru 90's in various hp ranges. Bunch of V4/V6 Crossflow from 1 3/16'' thru 1 3/8'' (again ranging in model years and hp). Also some 90* Looper carbs. Its too much too list it all, but if you know what your looking for, let me know and I can check to see if i have it.
    Dan Cario
    1994 STV Mod-VP w/225HO Ficht Evinrude
    1987 22' Velocity w/225HO Evinrude E-Tec
    8 Post(s)
    Quote Originally Posted by Baja16 View Post
    Hi after a pair of v4 3 jet 1 5/15 carbs so 1980 till early 83
    Mar 2007
    Ontario, New York
    Hi after a pair of v4 140 3 jet 1 5/15 carbs so 1980 till early 83
    I have a set. sent you a PM
    Dan Cario
    Sep 2011
    maryland
    Are you selling as sets............or individual carburetors?
    Mar 2007
    Ontario, New York
    Quote Originally Posted by keefallan View Post
    I can do both. I have complete sets and various individual carbs. Let me know what you need and I'll look and see if I have it!
    Dan Cario
    Sep 2011
    maryland
    I am looking to replace a 1988 thru 1991 gt150 carb....1-5/16. I spilled...well the battery spilled its guts on one and..........wow what a mess. I don't "need" it but I would like to finish that set again. upper or lower
    Mar 2007
    Ontario, New York
    If you can get me the casting number off the front of the carb, i will see if i have one that matches!
    Dan Cario
    Sep 2007
    Kansas
    96 Evinrude 200hp
    I'm looking to up grade my carbs to the 225hp mid bore carbs (1.45"), would you have a set of them in good shape?
  1. OMC Tech: Older 75hp evinrude carbs vs 86' 70hp johnson carbs
    By roycesrolls in forum Technical Discussion
    Last Post: 06-01-2012, 08:24 PM
