Results 16 to 30 of 55
Thread: Aftermarket Reeds for OMC V6
02-01-2019, 05:29 PM #16
So how many times do you have to beat your opinion drum to get your point across?
So falsely stating the reeds were cracked was an opinion? Even though nothing was mentioned about a crack? That is perpetuating false information. The OP also said:The above are reeds that should live well in every day use.
02-01-2019, 05:35 PM #17
So when al said that the BOYSEENS split on start up , I took that as a crack also ,which I do believe is same thing, look no need try ruffle feathers here , we r all here for same thing. No need get all pissed off cause u like boyseens , it's what the man said, "split"
02-01-2019, 06:53 PM #18
'84 Checkmate Convincor
02-01-2019, 07:24 PM #19
Ouch !! Everyone has their preference, and if u or anyone else like boyseenthen that's just fine , no harm no fowl ,but others mite like diff brand and if so then more power to em, I just didnt see why sumone needed start argument over it , the proof is in the pudding sort of thing , and as for.me I've never had prob with stock steel so they bout gud as any also , I hope everyone has gud luck with what ever they decide to run
02-01-2019, 07:38 PM #20
I think its bout time for reed talk to come to end on this thread, still kinda hard believe it took the then turn it did over 1 OPINION
02-01-2019, 07:53 PM #21Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
02-01-2019, 09:10 PM #22Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
To clarify it says spit not split.
FMP liked this post
02-01-2019, 10:24 PM #23
02-01-2019, 10:26 PM #24
He is him...he meant spit
02-01-2019, 10:28 PM #25
02-02-2019, 07:37 AM #26Scream And Fly VIP
- May 2001
- Hickory NC
- 5,583
- 18
- 250
- 204
- 464
- 4 Post(s)
Had a slight spit out carb on fire up that cleared as soon as running. Due to having a couple that had about .010 opening. None were broken or cracked and made the same power as on first fire up.
Mrichartz the stops in your photo are the early version the later ones have more material before opening between each stop.
02-02-2019, 08:20 AM #27
02-02-2019, 01:11 PM #28
02-03-2019, 02:16 PM #297000 RPM
- Mar 2009
- Port Saint Lucie
- 2,523
- 31
- 250
Ok. Due to running issues I've pulled all the carbs off and took the reed plate off. The reeds are steel. Gonna rebuild the carbs. Should I change reeds? I was told they were boyeson reeds.
02-03-2019, 02:32 PM #30Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
You could put Boyesen in replacing the steel.
Mercury Tech: fiber reeds and steel reeds in same motor
By buzmacdowell in forum Technical DiscussionReplies: 4Last Post: 07-09-2011, 10:06 PM -
oem vs aftermarket
By k-man in forum Technical DiscussionReplies: 9Last Post: 03-21-2009, 02:00 PM
