Page 7 of 7 FirstFirst 1 2 3 4 5 6 7
Results 91 to 97 of 97
  1. #91
    Daytona Fl.
    7 Post(s)
    The 5 blade that JR got is a Drag 5 prop, same as Drag 4 but 5 blades, not to be confused with the Hill 5 blade cleaver. I have the Drag 5's for $975 to your door. Comes out of the hole much faster and much less slip at cruise speeds.
    Boat Delivery available
    Things owned. NOTHING!!
  2. #92
    Daytona Fl.
    7 Post(s)
    I've been selling lots of these. I sold a pair to a 28 Nordic with 400's. Fastest he saw with Mercury CNC's was 124. The Hill's saw 125
  3. Likes powerabout, Toffen liked this post
  4. #93
    Norway
    Hi Randy,
    If I am correct Hills will offer a 5 bl 26 pitch cleaver late spring. Is this correct?
    If so, is it possible to choose between 15/20 degree too?
    Thanks !
    Cheeers, Toffen
  5. #94
    Daytona Fl.
    7 Post(s)
    I JUST CALLED THEM. tHEY WILL BE 20 DEGREE ONLY. THEY ARE WORKING ON THE LH PROP. I HAVE A PAIR OF 26'S ORDERED
    Quote Originally Posted by Toffen View Post
    Hi Randy,
    Thanks !
    Cheeers, Toffen
  6. #95
    Norway
    Hi !
    Thanks
    Great Is it the same price as the 28 pitch. My boat is a V and runs 6,8 % slip with a Max5 25 on the rev limiter. The boat needs a little bowlift, so I presume the 20 degree will be ok. If buying a Merc CNC cleaver I was reccomended 18 degree.
    Cheeers, Toffen
  7. #96
    Daytona Fl.
    7 Post(s)
    Yes, they are all the same price. My 21 and 22's picked up 10 mph over the Max5.
  8. #97
    Apr 2010
    Indian Lake Ohio
    Quote Originally Posted by WILDMAN View Post
    I just ran the 32x15 Hill 5 blade on my 25 Liberator with 300xs motors. No problem turning them and awesome acceleration. Too small for this boat. Ran 108-109 on the limiters at 6400. That's 9$ slip. Higher slip is most likely due to the smaller diameter. I put the 34x15.25 on the RH motor to see the slip difference. At 108, the 32x15" was 6350 rpm and the 34x15.25 was at 5700. Don't know if it was lifting the back or not. Still had 25-30 lbs of pressure, but did seems a little squirley at top speed. We also ran it on a 21 Liberator with a 300xs. It ran 96 with a 5 blade 31" Drag 5 at 5700. The 32 5 blade hill ran 99 at 5600. Too much prop and ran 5% slip.
    The main purpose of this prop test was to see if the 300xs had enough torque to turn the Bigger cleaver. No problem at all. It did give the 21 Liberator 3 more mph but we still need to test on more boats.
    Did you ever do any more testing or boat more with the five blades on a 25 liberator with XS power? Curious if you think they are a good fit or if two stroke twins on a 25 should stay with 3 or 4 blade props. Thank You!
  1. Mercury 300XS - $5000 (Gatesville)
    By noli in forum Ebay Listings and Other Internet Listings
    Last Post: 05-26-2019, 10:07 PM
  2. mercury 2.5 260 $5000
    By 2jz in forum Ebay Listings and Other Internet Listings
    Last Post: 01-13-2014, 04:05 PM
  3. Mercury Tech: Mercury 250 XS Opti no oversize pistons available, would like alternative
    By cactusth in forum Technical Discussion
    Last Post: 11-19-2012, 03:01 AM
  4. my mercury 200 2.5 will not go above 5000 rpm
    By shesha in forum Technical Discussion
    Last Post: 06-26-2011, 10:22 PM
