Results 61 to 75 of 97
02-09-2019, 10:54 PM #615000 RPM
- Jan 2003
- LA, CA
- 454
- 7
Kcraft liked this post
02-10-2019, 12:50 PM #625000 RPM
- Feb 2004
- 122
- 20
- 12
- 85
- 61
How did a cleaver on a F2 work? That is the Hallet F2 bottom right? Thanks
02-10-2019, 10:58 PM #635000 RPM
- Jan 2003
- LA, CA
- 454
- 7
Hallet f2 bottom, no it started out as a cyclone from ross then went to Hallet and I purchased the molds from hallet. I deleted lifting strakes and I deleted 18" of the ridding surface for a better big water ride with the cg more centered. The boat is better balanced for what I built it for big water. I hope the added weight higher and backwards of the new motor will still benefit from the Cg more centered. Time will tell with this new motor.
02-11-2019, 01:41 AM #64Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
I wonder how many boats with high propshafts and 300hp would benefit?
02-11-2019, 07:25 AM #65
02-11-2019, 11:42 AM #66
So far with my LayeyCraft 2750 with twin 300xs:
88.4 with 15" x 30" 4-blade Merc Lab cleavers very thin blades: 19% slip
91.0 with 15" x 30" 4-balde Dewald "not thinned" Cleavers: 16% slip
Dewald is sending me a set of 15-1/2" x 30" 4-balde Cleavers to see if we can lower the slip numbers by 2-3%
I know there is still a few more mph left to go. My boat gets up to these speeds and just hits a brick wall. When it passes over 6,100 - 6,200 rpms, it just stops pulling.
Getting there is really quick and fun.
All of these props have been very easy to get on plane with, hard to imagine that the 5-blades would not work, but an expensive gamble if they don't.
I would really like to know if the 300xs will turn a set of 15" or 15-1/2" x 30" 5-blades!!! Not wanting to paying $4.5k to find out they will not turn them.
With the very low slip numbers that the 5-blades are running, a 29" would probably work, and be easier to get on plane with.Last edited by MDRURY; 02-11-2019 at 11:48 AM.
02-11-2019, 02:49 PM #67
I'm getting a pair of 30's sent to me this week to test.
Boat Delivery available
Things owned. NOTHING!!
02-11-2019, 07:19 PM #68
02-11-2019, 07:37 PM #69
What pitch do you run? I'm getting a bunch of different props. 4 and 5 blade cleavers.
02-11-2019, 08:34 PM #70
I normally run 30p 15” 5blade Dewald’s thru-hub. Not sure on the rake. I turn them anywhere from 6500rpm to 6800rpm depending on the load. Running around 6% slip. I have a set of 32’s also but boat was a bit sluggish for my liking. I am huge Dewald fan but if this things really work would buy a set for sure. I just raised the motors recently a bit more and have not run it out since. May be another hundred or two now. Would be good comparison for them on a large cat that is a 2 stroke and not a 400r. It could open them up a whole new market.
Double Rigged
308 Skater w/400r’s
Over-Kill
02-11-2019, 09:06 PM #71
I'll let you know when I get them
02-11-2019, 09:51 PM #72
02-12-2019, 09:45 AM #735000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Subscribe
Been waiting to see someone try these new style propellers on some 2 stroke
Do some videos also
02-15-2019, 08:56 PM #746000 RPM
- Oct 2009
- Gonzales, La
- 1,085
- 114
- 69
- 218
- 355
Randy, how do you think these would perform on a boat that needs some bow lift?
02-16-2019, 02:20 PM #75
Randy,
I would love to come and try some of your props on my Grandsport 300XS/SM 1.62 and buy what works best. I would be glad to pay you for your time and then purchase a prop from you.
I think all of us appreciate the time and money you spend to improve OUR boating.....
Just let me know if you can do it.
JR
"Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington“I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
Allison GSE 300XS
HydroSkreamin liked this post
Mercury 300XS - $5000 (Gatesville)
By noli in forum Ebay Listings and Other Internet ListingsReplies: 7Last Post: 05-26-2019, 10:07 PM -
mercury 2.5 260 $5000
By 2jz in forum Ebay Listings and Other Internet ListingsReplies: 1Last Post: 01-13-2014, 04:05 PM -
Mercury Tech: Mercury 250 XS Opti no oversize pistons available, would like alternative
By cactusth in forum Technical DiscussionReplies: 3Last Post: 11-19-2012, 03:01 AM -
my mercury 200 2.5 will not go above 5000 rpm
By shesha in forum Technical DiscussionReplies: 9Last Post: 06-26-2011, 10:22 PM
