Results 16 to 30 of 34
Thread: Mercury 15 HP race motor
01-29-2019, 07:33 PM #16Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
01-29-2019, 07:57 PM #17Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Mostly dummies that didn't look after them with proper tuning.
It's true, I'm not the only one who has seen the Force.
01-30-2019, 08:09 PM #18Member
- Oct 2014
- Miami
- 39
FMP liked this post
01-30-2019, 08:21 PM #19Member
- Oct 2014
- Miami
- 39
01-30-2019, 08:25 PM #20Member
- Oct 2014
- Miami
- 39
Im also going to need a big carb for this motor so if anyone has a 20hp or 25hp please send me a PM!!!
01-30-2019, 09:55 PM #21Screaming And Flying!
- Feb 2015
- Ontario
- 8,091
- 205
- 321
- 1921
- 2005
Am I see things or does the bottom cylinder have a third downward facing port towards the tuner?
The view from the passage up , the right side semi circle corner. If you could use some high temp aluminum ceramic or weld fill it and grind smooth the curve. And the left side top edge, round the fall off nicely. With the cover on that last corner which forms on the bottom floor before the fall off towards the tuner. Does the cover have a shape to round that 90°. If it doesn't I'd try to make something work there so that S turn through to the tuner is more uniform and smooth.Last edited by FMP; 01-30-2019 at 10:41 PM.
01-31-2019, 09:04 AM #22Member
- Oct 2014
- Miami
- 39
No lol it’s the angle I took the picture. the port kinda wraps around cylinder so it looks like it goes downwards.
01-31-2019, 11:38 AM #23Member
- Oct 2014
- Miami
- 39
Also does anyone know where i can get props for this motor. ive seen cleaver looking props but can find any for a 15hp (8 spline)??
01-31-2019, 11:55 AM #24
Powertec and solas
02-11-2019, 10:03 AM #25Member
- Oct 2014
- Miami
- 39
05-02-2022, 03:37 AM #26Junior Member
- Apr 2022
- New zealand
I’m just wondering what sort of results did you get? Rpm and power wise?
05-03-2022, 10:15 AM #27
Carbs from 6hp to 25 were IDENTICAL except for the bore size and the jetting. I would not go up to a 25 hp carb on that 15 right away. That is likely going to bog as that small displacmtent probably won't make enough vacuum even with the mods you did. I would get an early 18hp carb for one and change the linkage to work from the early to the later. Then get the jetting for that figured out and make sure the motor can pull fuel right. If you have any questions feel free to pm me or call me, I did that stuff a lot a while ago.
The exhaust pipe isn't tuned on those motors either, so some modifications there can yield quite a bit.
05-03-2022, 01:33 PM #28Junior Member
- Apr 2022
- New zealand
25two.stroke liked this post
05-21-2022, 04:19 PM #29New Member
- May 2022
- Arkansas
05-24-2022, 06:47 PM #30(Apricot)
Hydrostream Ventura II/Merc (sold)
(Bruiser Scheme)
Hydrostream Viking/Merc (sold)
(tri color letdown scheme)
Hydrostream Valero/Merc
1991 Mirage Race Boat w/ 2.5 Mercury Motor and matching trailer FOR SALE!!!!
By still1graphics in forum Hulls up to 20'Replies: 13Last Post: 08-20-2020, 05:03 PM -
Brand New Mercury 200 SST race motor
By 3 STOOGES in forum Outboard EnginesReplies: 16Last Post: 10-15-2016, 10:16 PM -
Forget the Formula Race Merc ... the Selva is the real F4 race motor
By Mark75H in forum General Boating DiscussionReplies: 15Last Post: 08-14-2011, 09:47 AM
